staging: slicloss: replace init_timer by setup_timer
Author: Aya Mahfouz <mahfouz.saif.elyazal@gmail.com>
This patch replaces init_timer and the 2 step initialization of function
and data by setup_timer to make the code more concise.
The issue was discovered using the following coccinelle script:
expression ds, e1, e2;
-init_timer (&ds);
+setup_timer (&ds, e1, e2);
-ds.function = e1;
-ds.data = e2;
-ds.data = e2;
-ds.function = e1;
Signed-off-by: Aya Mahfouz
drivers/staging/slicoss/slicoss.c | 9 +++------
1 file changed, 3 insertions(+), 6 deletions(-)
diff --git a/drivers/staging/slicoss/slicoss.c b/drivers/staging/slicoss/slicoss.c
index 42d62ef..1248f62 100644
--- a/drivers/staging/slicoss/slicoss.c
+++ b/drivers/staging/slicoss/slicoss.c
@@ -2362,22 +2362,19 @@ static int slic_if_init(struct adapter *adapter)
adapter->state = ADAPT_UP;
if (!card->loadtimerset) {
- init_timer(&card->loadtimer);
+ setup_timer(&card->loadtimer, &slic_timer_load_check,
+ (ulong)card);
card->loadtimer.expires =
jiffies + (SLIC_LOADTIMER_PERIOD * HZ);
- card->loadtimer.data = (ulong) card;
- card->loadtimer.function = &slic_timer_load_check;
add_timer(&card->loadtimer);
card->loadtimerset = 1;
if (!adapter->pingtimerset) {
- init_timer(&adapter->pingtimer);
+ setup_timer(&adapter->pingtimer, &slic_timer_ping, (ulong)dev);
adapter->pingtimer.expires =
jiffies + (PING_TIMER_INTERVAL * HZ);
- adapter->pingtimer.data = (ulong) dev;
- adapter->pingtimer.function = &slic_timer_ping;
add_timer(&adapter->pingtimer);
adapter->pingtimerset = 1;
adapter->card->pingstatus = ISR_PINGMASK; |
+ (ulong)card);
