staging: rtl8192u: ieee80211: replace init_timer by setup_timer
Author: Aya Mahfouz <mahfouz.saif.elyazal@gmail.com>
This patch replaces init_timer and the 2 step initialization of function
and data by setup_timer to make the code more concise.
The issue was discovered using the following coccinelle script:
expression ds, e1, e2;
-init_timer (&ds);
+setup_timer (&ds, e1, e2);
-ds.function = e1;
-ds.data = e2;
-ds.data = e2;
-ds.function = e1;
Signed-off-by: Aya Mahfouz
drivers/staging/rtl8192u/ieee80211/ieee80211_softmac.c | 10 ++++------
1 file changed, 4 insertions(+), 6 deletions(-)
diff --git a/drivers/staging/rtl8192u/ieee80211/ieee80211_softmac.c b/drivers/staging/rtl8192u/ieee80211/ieee80211_softmac.c
index d147187..3a54071 100644
--- a/drivers/staging/rtl8192u/ieee80211/ieee80211_softmac.c
+++ b/drivers/staging/rtl8192u/ieee80211/ieee80211_softmac.c
@@ -2722,13 +2722,11 @@ void ieee80211_softmac_init(struct ieee80211_device *ieee)
ieee->enable_rx_imm_BA = 1;
ieee->tx_pending.txb = NULL;
- init_timer(&ieee->associate_timer);
- ieee->associate_timer.data = (unsigned long)ieee;
- ieee->associate_timer.function = ieee80211_associate_abort_cb;
+ setup_timer(&ieee->associate_timer, ieee80211_associate_abort_cb,
+ (unsigned long)ieee);
- init_timer(&ieee->beacon_timer);
- ieee->beacon_timer.data = (unsigned long) ieee;
- ieee->beacon_timer.function = ieee80211_send_beacon_cb;
+ setup_timer(&ieee->beacon_timer, ieee80211_send_beacon_cb,
ieee->wq = create_workqueue(DRV_NAME); |
