Staging: rts5208: clean dev_err logging
Author: Haneen Mohammed <hamohammed.sa@gmail.com>
This patch removes  __func__ from dev_err. dev_err includes information about:
(devcice, driver, specific instance of device, etc) in the log printout.
This was done using Coccinelle, with the following semantic patch:
@a@
expression E, R;
expression  msg;
dev_err(E, msg, __func__, R);
@script:python b@
e << a.msg;
y;
if(e.find("%s: ") == True):
	m = e.replace("%s: ", "", 1);
	coccinelle.y = m;
elif(e.find("%s ") == True):
	m = e.replace("%s ", "", 1);
	coccinelle.y = m;
elif(e.find("%s:") == True):
	m = e.replace("%s:", "", 1);
	coccinelle.y = m;
else:
	m = e.replace("%s", "",1);
	coccinelle.y = m;
@c@
expression a.E, a.msg, a.R;
identifier  b.y;
- dev_err(E, msg, __func__, R);
+ dev_err(E, y, R);
Signed-off-by: Haneen Mohammed
 drivers/staging/rts5208/rtsx.c | 4 ++--
 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/staging/rts5208/rtsx.c b/drivers/staging/rts5208/rtsx.c
index c74f1b8..7f2c0c3 100644
--- a/drivers/staging/rts5208/rtsx.c
+++ b/drivers/staging/rts5208/rtsx.c
@@ -137,8 +137,8 @@ static int queuecommand_lck(struct scsi_cmnd *srb,
 	/* check for state-transition errors */
 	if (chip->srb != NULL) {
-		dev_err(&dev->pci->dev, "Error in %s: chip->srb = %p\n",
-			__func__, chip->srb);
+		dev_err(&dev->pci->dev, "Error: chip->srb = %p\n",
+			chip->srb);
 		return SCSI_MLQUEUE_HOST_BUSY;
BtrLinux
Privacy Overview
