drivers/staging/comedi/drivers/ni_mio_common.c | 4 ++--
drivers/staging/comedi/drivers/usbduxsigma.c | 26 +++++++++++---------------
2 files changed, 13 insertions(+), 17 deletions(-)
diff --git a/drivers/staging/comedi/drivers/ni_mio_common.c b/drivers/staging/comedi/drivers/ni_mio_common.c
index 176b64a..97728d2 100644
--- a/drivers/staging/comedi/drivers/ni_mio_common.c
+++ b/drivers/staging/comedi/drivers/ni_mio_common.c
@@ -670,8 +670,8 @@ static inline void ni_set_bitfield(struct comedi_device *dev, int reg,
ni_writeb(dev, devpriv->g0_g1_select_reg, G0_G1_Select);
break;
default:
- dev_err(dev->class_dev,
- "%s called with invalid register %d\n", __func__, reg);
+ dev_err(dev->class_dev, "called with invalid register %d\n",
+ reg);
break;
mmiowb();
diff --git a/drivers/staging/comedi/drivers/usbduxsigma.c b/drivers/staging/comedi/drivers/usbduxsigma.c
index 394969b..f50cf8a 100644
--- a/drivers/staging/comedi/drivers/usbduxsigma.c
+++ b/drivers/staging/comedi/drivers/usbduxsigma.c
@@ -243,9 +243,8 @@ static void usbduxsigma_ai_handle_urb(struct comedi_device *dev,
urb->dev = comedi_to_usb_dev(dev);
ret = usb_submit_urb(urb, GFP_ATOMIC);
if (ret < 0) {
- "%s: urb resubmit failed (%d)\n",
- __func__, ret);
+ dev_err(dev->class_dev, "urb resubmit failed (%d)\n",
+ ret);
if (ret == -EL2NSYNC)
"buggy USB host controller or bug in IRQ handler\n");
@@ -292,8 +291,8 @@ static void usbduxsigma_ai_urb_complete(struct urb *urb)
default:
/* a real error */
- dev_err(dev->class_dev, "%s: non-zero urb status (%d)\n",
- __func__, urb->status);
+ dev_err(dev->class_dev, "non-zero urb status (%d)\n",
+ urb->status);
async->events |= COMEDI_CB_ERROR;
break;
@@ -386,9 +385,8 @@ static void usbduxsigma_ao_handle_urb(struct comedi_device *dev,
urb->iso_frame_desc[0].status = 0;
if (ret < 0) {
- __func__, ret);
+ ret);
@@ -423,8 +421,8 @@ static void usbduxsigma_ao_urb_complete(struct urb *urb)
default:
/* a real error */
+ urb->status);
break;
@@ -1071,9 +1069,8 @@ static void usbduxsigma_pwm_urb_complete(struct urb *urb)
default:
/* a real error */
if (devpriv->pwm_cmd_running) {
- "%s: non-zero urb status (%d)\n",
+ urb->status);
usbduxsigma_pwm_stop(dev, 0); /* w/o unlink */
return;
@@ -1087,8 +1084,7 @@ static void usbduxsigma_pwm_urb_complete(struct urb *urb)
urb->status = 0;
if (ret < 0) {
- dev_err(dev->class_dev, "%s: urb resubmit failed (%d)\n",
- __func__, ret);
+ dev_err(dev->class_dev, "urb resubmit failed (%d)\n", ret);
"buggy USB host controller or bug in IRQ handler\n"); |
