staging: rtl8723au: remove extra parentheses around right bit shift operations
Author: Aya Mahfouz <mahfouz.saif.elyazal@gmail.com>
Removes extra parentheses around bitwise right shift operations.
The cases handled here are when resultant values are assigned to
variables. The issue was detected and resolved using the following
coccinelle script:
expression e, e1;
constant c;
e =
-(e1
+e1
-c);
+c;
identifier i;
constant c;
type t;
expression e;
t i =
-(e
+e
-c);
+c;
expression e, e1;
identifier f;
constant c;
e1 = f(...,
-(e
+e
-c)
+c
Signed-off-by: Aya Mahfouz
 drivers/staging/rtl8723au/hal/odm.c               | 6 +++---
 drivers/staging/rtl8723au/hal/rtl8723a_hal_init.c | 6 +++---
 2 files changed, 6 insertions(+), 6 deletions(-)
diff --git a/drivers/staging/rtl8723au/hal/odm.c b/drivers/staging/rtl8723au/hal/odm.c
index 8d42661..2d3653e 100644
--- a/drivers/staging/rtl8723au/hal/odm.c
+++ b/drivers/staging/rtl8723au/hal/odm.c
@@ -736,15 +736,15 @@ void odm_FalseAlarmCounterStatistics23a(struct dm_odm_t *pDM_Odm)
 	ret_value =
 		ODM_GetBBReg(pDM_Odm, ODM_REG_OFDM_FA_TYPE1_11N, bMaskDWord);
 	FalseAlmCnt->Cnt_Fast_Fsync = (ret_value&0xffff);
-	FalseAlmCnt->Cnt_SB_Search_fail = ((ret_value&0xffff0000)>>16);
+	FalseAlmCnt->Cnt_SB_Search_fail = (ret_value & 0xffff0000)>>16;
 	ret_value =
 		ODM_GetBBReg(pDM_Odm, ODM_REG_OFDM_FA_TYPE2_11N, bMaskDWord);
 	FalseAlmCnt->Cnt_OFDM_CCA = (ret_value&0xffff);
-	FalseAlmCnt->Cnt_Parity_Fail = ((ret_value&0xffff0000)>>16);
+	FalseAlmCnt->Cnt_Parity_Fail = (ret_value & 0xffff0000)>>16;
 	ret_value =
 		ODM_GetBBReg(pDM_Odm, ODM_REG_OFDM_FA_TYPE3_11N, bMaskDWord);
 	FalseAlmCnt->Cnt_Rate_Illegal = (ret_value&0xffff);
-	FalseAlmCnt->Cnt_Crc8_fail = ((ret_value&0xffff0000)>>16);
+	FalseAlmCnt->Cnt_Crc8_fail = (ret_value & 0xffff0000)>>16;
 	ret_value =
 		ODM_GetBBReg(pDM_Odm, ODM_REG_OFDM_FA_TYPE4_11N, bMaskDWord);
 	FalseAlmCnt->Cnt_Mcs_fail = (ret_value&0xffff);
diff --git a/drivers/staging/rtl8723au/hal/rtl8723a_hal_init.c b/drivers/staging/rtl8723au/hal/rtl8723a_hal_init.c
index 7b3fdc8..ebe3339 100644
--- a/drivers/staging/rtl8723au/hal/rtl8723a_hal_init.c
+++ b/drivers/staging/rtl8723au/hal/rtl8723a_hal_init.c
@@ -751,7 +751,7 @@ void rtl8723a_read_chip_version(struct rtw_adapter *padapter)
 	value32 = rtl8723au_read32(padapter, REG_GPIO_OUTSTS);
 	/*  ROM code version. */
-	ChipVersion.ROMVer = ((value32 & RF_RL_ID) >> 20);
+	ChipVersion.ROMVer = (value32 & RF_RL_ID) >> 20;
 	/*  For multi-function consideration. Added by Roger, 2010.10.06. */
 	pHalData->MultiFunc = RT_MULTI_FUNC_NONE;
@@ -1728,8 +1728,8 @@ Hal_EfuseParseBTCoexistInfo_8723A(struct rtw_adapter *padapter,
 		/*  eeprom spec */
 		tempval = hwinfo[RF_OPTION4_8723A];
 		pHalData->EEPROMBluetoothAntNum = (tempval & 0x1);
-		pHalData->EEPROMBluetoothAntIsolation = ((tempval & 0x10) >> 4);
-		pHalData->EEPROMBluetoothRadioShared = ((tempval & 0x20) >> 5);
+		pHalData->EEPROMBluetoothAntIsolation = (tempval & 0x10) >> 4;
+		pHalData->EEPROMBluetoothRadioShared = (tempval & 0x20) >> 5;
 	} else {
 		pHalData->EEPROMBluetoothCoexist = 0;
 		pHalData->EEPROMBluetoothType = BT_RTL8723A;
BtrLinux
Privacy Overview
