staging: rtl8712: remove extra parentheses around right bit shift operation
Author: Aya Mahfouz <mahfouz.saif.elyazal@gmail.com>
Removes extra parentheses around bitwise right shift operation.
The cases handled are  when the resultant value is assigned to
a variable or when a shift operation is carried out for a function
argument. The issues were detected and resolved using the following
coccinelle script:
expression e, e1;
constant c;
e =
-(e1
+e1
-c);
+c;
identifier i;
constant c;
type t;
expression e;
t i =
-(e
+e
-c);
+c;
expression e, e1;
identifier f;
constant c;
e1 = f(...,
-(e
+e
-c)
+c
Signed-off-by: Aya Mahfouz
 drivers/staging/rtl8712/rtl8712_recv.c | 4 ++--
 drivers/staging/rtl8712/rtl871x_mp.c   | 4 ++--
 2 files changed, 4 insertions(+), 4 deletions(-)
diff --git a/drivers/staging/rtl8712/rtl8712_recv.c b/drivers/staging/rtl8712/rtl8712_recv.c
index 0ec0bda..50227b5 100644
--- a/drivers/staging/rtl8712/rtl8712_recv.c
+++ b/drivers/staging/rtl8712/rtl8712_recv.c
@@ -166,7 +166,7 @@ static void update_recvframe_attrib_from_recvstat(struct rx_pkt_attrib *pattrib,
 	 * Offset 0 */
 	pattrib->bdecrypted = ((le32_to_cpu(prxstat->rxdw0) & BIT(27)) >> 27)
 				 ? 0 : 1;
-	pattrib->crc_err = ((le32_to_cpu(prxstat->rxdw0) & BIT(14)) >> 14);
+	pattrib->crc_err = (le32_to_cpu(prxstat->rxdw0) & BIT(14)) >> 14;
 	/*Offset 4*/
 	/*Offset 8*/
 	/*Offset 12*/
@@ -435,7 +435,7 @@ void r8712_rxcmd_event_hdl(struct _adapter *padapter, void *prxcmdbuf)
 	poffset = (u8 *)prxcmdbuf;
 	voffset = *(uint *)poffset;
 	prxstat = (struct recv_stat *)prxcmdbuf;
-	drvinfo_sz = ((le32_to_cpu(prxstat->rxdw0) & 0x000f0000) >> 16);
+	drvinfo_sz = (le32_to_cpu(prxstat->rxdw0) & 0x000f0000) >> 16;
 	drvinfo_sz <<= 3;
 	poffset += RXDESC_SIZE + drvinfo_sz;
 	do {
diff --git a/drivers/staging/rtl8712/rtl871x_mp.c b/drivers/staging/rtl8712/rtl871x_mp.c
index 3d913b9..26201ea 100644
--- a/drivers/staging/rtl8712/rtl871x_mp.c
+++ b/drivers/staging/rtl8712/rtl871x_mp.c
@@ -327,8 +327,8 @@ void r8712_SetTxAGCOffset(struct _adapter *pAdapter, u32 ulTxAGCOffset)
 	u32 TxAGCOffset_B, TxAGCOffset_C, TxAGCOffset_D, tmpAGC;
 	TxAGCOffset_B = (ulTxAGCOffset&0x000000ff);
-	TxAGCOffset_C = ((ulTxAGCOffset&0x0000ff00)>>8);
-	TxAGCOffset_D = ((ulTxAGCOffset&0x00ff0000)>>16);
+	TxAGCOffset_C = (ulTxAGCOffset & 0x0000ff00)>>8;
+	TxAGCOffset_D = (ulTxAGCOffset & 0x00ff0000)>>16;
 	tmpAGC = (TxAGCOffset_D<<8 | TxAGCOffset_C<<4 | TxAGCOffset_B);
 	set_bb_reg(pAdapter, rFPGA0_TxGainStage,
 			(bXBTxAGC|bXCTxAGC|bXDTxAGC), tmpAGC);
