staging: rtl8723au: delete successive assignments to the same location
Author: Jiayi Ye <yejiayily@gmail.com>
Successive assignments to the same location is meaningless and can be
deleted. The Coccinelle semantic patch was used to find cases.
expression e1,e2,e3;
 (<+...e1++...+>)=e2;
 (<+...e1--...+>)=e2;
 (<+...++e1...+>)=e2;
 (<+...--e1...+>)=e2;
e1=e2;
e1 = <+...e1...+>;
*e1=e2;
*e1=e3;
Signed-off-by: Jiayi Ye
Reviewed-by: Josh Triplett
 drivers/staging/rtl8723au/core/rtw_mlme_ext.c     | 2 --
 drivers/staging/rtl8723au/hal/usb_halinit.c       | 1 -
 drivers/staging/rtl8723au/os_dep/ioctl_cfg80211.c | 1 -
 3 files changed, 4 deletions(-)
diff --git a/drivers/staging/rtl8723au/core/rtw_mlme_ext.c b/drivers/staging/rtl8723au/core/rtw_mlme_ext.c
index 86f5217..10f8031 100644
--- a/drivers/staging/rtl8723au/core/rtw_mlme_ext.c
+++ b/drivers/staging/rtl8723au/core/rtw_mlme_ext.c
@@ -2339,8 +2339,6 @@ static int update_hidden_ssid(u8 *ies, u32 ies_len, u8 hidden_ssid_mode)
 		switch (hidden_ssid_mode) {
 		case 1:
 			next_ie = ssid_ie + 2 + ssid_len_ori;
-			remain_len = 0;
 			remain_len = ies_len -(next_ie-ies);
 			ssid_ie[1] = 0;
diff --git a/drivers/staging/rtl8723au/hal/usb_halinit.c b/drivers/staging/rtl8723au/hal/usb_halinit.c
index a5de03d..6c1dcf0 100644
--- a/drivers/staging/rtl8723au/hal/usb_halinit.c
+++ b/drivers/staging/rtl8723au/hal/usb_halinit.c
@@ -1485,7 +1485,6 @@ void rtl8723a_update_ramask(struct rtw_adapter *padapter,
 	/* mask &= 0x0fffffff; */
-	rate_bitmap = 0x0fffffff;
 	rate_bitmap = ODM_Get_Rate_Bitmap23a(pHalData, mac_id, mask,
 					     rssi_level);
 	DBG_8723A("%s => mac_id:%d, networkType:0x%02x, "
diff --git a/drivers/staging/rtl8723au/os_dep/ioctl_cfg80211.c b/drivers/staging/rtl8723au/os_dep/ioctl_cfg80211.c
index 2f01714..e154de9 100644
--- a/drivers/staging/rtl8723au/os_dep/ioctl_cfg80211.c
+++ b/drivers/staging/rtl8723au/os_dep/ioctl_cfg80211.c
@@ -2363,7 +2363,6 @@ void rtw_cfg80211_indicate_sta_assoc(struct rtw_adapter *padapter,
 			ie_offset = offsetof(struct ieee80211_mgmt,
 					     u.reassoc_req.variable);
-		sinfo.filled = 0;
 		sinfo.filled = STATION_INFO_ASSOC_REQ_IES;
 		sinfo.assoc_req_ies = pmgmt_frame + ie_offset;
 		sinfo.assoc_req_ies_len = frame_len - ie_offset;
BtrLinux
Privacy Overview
