staging: rtl8192u: remove extra parentheses around right bit shift operation
Author: Aya Mahfouz <mahfouz.saif.elyazal@gmail.com>
Removes extra parentheses around bitwise right shift operation.
The cases handled are when the resultant value is assigned to
a variable or when a shift operation is carried out for a function
argument. The issues were detected and resolved using the following
coccinelle script:
expression e, e1;
constant c;
e =
-(e1
+e1
-c);
+c;
identifier i;
constant c;
type t;
expression e;
t i =
-(e
+e
-c);
+c;
expression e, e1;
identifier f;
constant c;
e1 = f(...,
-(e
+e
-c)
+c
Some coding style issues were handled manually to avoid
checkpatch warnings and errors.
Signed-off-by: Aya Mahfouz
 drivers/staging/rtl8192u/r8192U_core.c | 16 +++++++++-------
 1 file changed, 9 insertions(+), 7 deletions(-)
diff --git a/drivers/staging/rtl8192u/r8192U_core.c b/drivers/staging/rtl8192u/r8192U_core.c
index 9de4412..bab7751 100644
--- a/drivers/staging/rtl8192u/r8192U_core.c
+++ b/drivers/staging/rtl8192u/r8192U_core.c
@@ -2310,11 +2310,11 @@ static void rtl8192_read_eeprom_info(struct net_device *dev)
 	if (bLoad_From_EEPOM) {
-		tmpValue = eprom_read(dev, (EEPROM_VID>>1));
+		tmpValue = eprom_read(dev, EEPROM_VID>>1);
 		priv->eeprom_vid = endian_swap(&tmpValue);
-		priv->eeprom_pid = eprom_read(dev, (EEPROM_PID>>1));
-		tmpValue = eprom_read(dev, (EEPROM_ChannelPlan>>1));
-		priv->eeprom_ChannelPlan = ((tmpValue&0xff00)>>8);
+		priv->eeprom_pid = eprom_read(dev, EEPROM_PID>>1);
+		tmpValue = eprom_read(dev, EEPROM_ChannelPlan>>1);
+		priv->eeprom_ChannelPlan = (tmpValue & 0xff00)>>8;
 		priv->btxpowerdata_readfromEEPORM = true;
 		priv->eeprom_CustomerID = eprom_read(dev, (EEPROM_Customer_ID>>1)) >>8;
 	} else {
@@ -2397,7 +2397,8 @@ static void rtl8192_read_eeprom_info(struct net_device *dev)
 		} else if (priv->EEPROM_Def_Ver == 1) {
-				tmpValue = eprom_read(dev, (EEPROM_TxPwIndex_CCK_V1>>1));
+						EEPROM_TxPwIndex_CCK_V1 >> 1);
 				tmpValue = (tmpValue & 0xff00) >> 8;
 			} else {
 				tmpValue = 0x10;
@@ -2410,7 +2411,8 @@ static void rtl8192_read_eeprom_info(struct net_device *dev)
 				tmpValue = 0x1010;
 			*((u16 *)(&priv->EEPROMTxPowerLevelCCK_V1[1])) = tmpValue;
-				tmpValue = eprom_read(dev, (EEPROM_TxPwIndex_OFDM_24G_V1>>1));
+					EEPROM_TxPwIndex_OFDM_24G_V1 >> 1);
 			else
 				tmpValue = 0x1010;
 			*((u16 *)(&priv->EEPROMTxPowerLevelOFDM24G[0])) = tmpValue;
@@ -2453,7 +2455,7 @@ static void rtl8192_read_eeprom_info(struct net_device *dev)
 		// Antenna B gain offset to antenna A, bit0~3
 		priv->AntennaTxPwDiff[0] = (priv->EEPROMTxPowerDiff & 0xf);
 		// Antenna C gain offset to antenna A, bit4~7
-		priv->AntennaTxPwDiff[1] = ((priv->EEPROMTxPowerDiff & 0xf0)>>4);
+		priv->AntennaTxPwDiff[1] = (priv->EEPROMTxPowerDiff & 0xf0)>>4;
 		// CrystalCap, bit12~15
 		priv->CrystalCap = priv->EEPROMCrystalCap;
 		// ThermalMeter, bit0~3 for RFIC1, bit4~7 for RFIC2
BtrLinux
Privacy Overview
