staging: rtl8192u: ieee80211: ieee80211_softmac: Replace MSECS with msecs_to_jiffies
Author: Amitoj Kaur Chawla <amitoj1606@gmail.com>
Replace driver specific macro MSECS with msecs_to_jiffies().
This was found using the following Coccinelle semantic patch:
expression e;
- MSECS(e)
+ msecs_to_jiffies(e)
Signed-off-by: Amitoj Kaur Chawla
 drivers/staging/rtl8192u/ieee80211/ieee80211_softmac.c | 9 ++++++---
 1 file changed, 6 insertions(+), 3 deletions(-)
diff --git a/drivers/staging/rtl8192u/ieee80211/ieee80211_softmac.c b/drivers/staging/rtl8192u/ieee80211/ieee80211_softmac.c
index 21ee410..6d85648 100644
--- a/drivers/staging/rtl8192u/ieee80211/ieee80211_softmac.c
+++ b/drivers/staging/rtl8192u/ieee80211/ieee80211_softmac.c
@@ -380,7 +380,8 @@ static void ieee80211_send_beacon(struct ieee80211_device *ieee)
 	if (ieee->beacon_txing && ieee->ieee_up) {
 //		if(!timer_pending(&ieee->beacon_timer))
 //			add_timer(&ieee->beacon_timer);
-		mod_timer(&ieee->beacon_timer,jiffies+(MSECS(ieee->current_network.beacon_interval-5)));
+		mod_timer(&ieee->beacon_timer,
+			  jiffies + msecs_to_jiffies(ieee->current_network.beacon_interval-5));
 	//spin_unlock_irqrestore(&ieee->beacon_lock,flags);
@@ -1735,10 +1736,12 @@ static short ieee80211_sta_ps_sleep(struct ieee80211_device *ieee, u32 *time_h,
 	if(dtim & ((IEEE80211_DTIM_UCAST | IEEE80211_DTIM_MBCAST)& ieee->ps))
 		return 2;
-	if(!time_after(jiffies, ieee->dev->trans_start + MSECS(timeout)))
+	if(!time_after(jiffies,
+		       ieee->dev->trans_start + msecs_to_jiffies(timeout)))
 		return 0;
-	if(!time_after(jiffies, ieee->last_rx_ps_time + MSECS(timeout)))
+		       ieee->last_rx_ps_time + msecs_to_jiffies(timeout)))
 		return 0;
 	if((ieee->softmac_features & IEEE_SOFTMAC_SINGLE_QUEUE ) &&
BtrLinux
Privacy Overview
