staging: rtl8192u: ieee80211: ieee80211_rx: Replace MSECS with msecs_to_jiffies
Author: Amitoj Kaur Chawla <amitoj1606@gmail.com>
Replace driver specific macro MSECS with msecs_to_jiffies().
This was found using the following Coccinelle semantic patch:
expression e;
- MSECS(e)
+ msecs_to_jiffies(e)
Signed-off-by: Amitoj Kaur Chawla
drivers/staging/rtl8192u/ieee80211/ieee80211_rx.c | 3 ++-
1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/drivers/staging/rtl8192u/ieee80211/ieee80211_rx.c b/drivers/staging/rtl8192u/ieee80211/ieee80211_rx.c
index 28ad63a..9dfde07 100644
--- a/drivers/staging/rtl8192u/ieee80211/ieee80211_rx.c
+++ b/drivers/staging/rtl8192u/ieee80211/ieee80211_rx.c
@@ -761,7 +761,8 @@ static void RxReorderIndicatePacket(struct ieee80211_device *ieee,
pTS->RxTimeoutIndicateSeq = pTS->RxIndicateSeq;
if(timer_pending(&pTS->RxPktPendingTimer))
del_timer_sync(&pTS->RxPktPendingTimer);
- pTS->RxPktPendingTimer.expires = jiffies + MSECS(pHTInfo->RxReorderPendingTime);
+ pTS->RxPktPendingTimer.expires = jiffies +
+ msecs_to_jiffies(pHTInfo->RxReorderPendingTime);
add_timer(&pTS->RxPktPendingTimer);
