Staging: rtl8192e: rtl8192e: Remove assigned unused variable
Author: Mahati Chamarthy <mahati.chamarthy@gmail.com>
This patch removes an initialized variable which has never been used.
The following Coccinelle semantic patch was used to make this transformation:
@e@
identifier i;
position p;
type T;
extern T i@p;
type T;
identifier i;
constant C;
position p != e.p;
- T i@p;
  <+... when != i
- i = C;
The braces around if and else which become unnecessary after the transformation
were also removed.
Signed-off-by: Mahati Chamarthy
 drivers/staging/rtl8192e/rtl8192e/r8192E_cmdpkt.c | 8 ++------
 1 file changed, 2 insertions(+), 6 deletions(-)
diff --git a/drivers/staging/rtl8192e/rtl8192e/r8192E_cmdpkt.c b/drivers/staging/rtl8192e/rtl8192e/r8192E_cmdpkt.c
index 79d86b9..2b1430d 100644
--- a/drivers/staging/rtl8192e/rtl8192e/r8192E_cmdpkt.c
+++ b/drivers/staging/rtl8192e/rtl8192e/r8192E_cmdpkt.c
@@ -153,18 +153,14 @@ static void cmpk_handle_tx_feedback(struct net_device *dev, u8 *pmsg)
 static void cmdpkt_beacontimerinterrupt_819xusb(struct net_device *dev)
 	struct r8192_priv *priv = rtllib_priv(dev);
-	u16 tx_rate;
 	if ((priv->rtllib->current_network.mode == IEEE_A)  ||
 	    (priv->rtllib->current_network.mode == IEEE_N_5G) ||
 	    ((priv->rtllib->current_network.mode == IEEE_N_24G)  &&
-	    (!priv->rtllib->pHTInfo->bCurSuppCCK))) {
-		tx_rate = 60;
+	    (!priv->rtllib->pHTInfo->bCurSuppCCK)))
 		DMESG("send beacon frame  tx rate is 6Mbpm\n");
-	} else {
-		tx_rate = 10;
+	else
 		DMESG("send beacon frame  tx rate is 1Mbpm\n");
 static void cmpk_handle_interrupt_status(struct net_device *dev, u8 *pmsg)
BtrLinux
Privacy Overview
