Staging: rtl8192e: Remove unused variable
Author: Mahati Chamarthy <mahati.chamarthy@gmail.com>
This patch removes a variable which has never been used. The following
Coccinelle semantic patch was used to make this transformation:
type T;
identifier i;
constant C;
- T i;
<... when != i
- i = C;
Signed-off-by: Mahati Chamarthy
Acked-by: Julia Lawall
drivers/staging/rtl8192e/rtllib_softmac_wx.c | 2 --
1 file changed, 2 deletions(-)
diff --git a/drivers/staging/rtl8192e/rtllib_softmac_wx.c b/drivers/staging/rtl8192e/rtllib_softmac_wx.c
index d077f49..835f3d7 100644
--- a/drivers/staging/rtl8192e/rtllib_softmac_wx.c
+++ b/drivers/staging/rtl8192e/rtllib_softmac_wx.c
@@ -335,7 +335,6 @@ void rtllib_wx_sync_scan_wq(void *data)
enum ht_extchnl_offset chan_offset = 0;
enum ht_channel_width bandwidth = 0;
int b40M = 0;
- static int count;
if (!(ieee->softmac_features & IEEE_SOFTMAC_SCAN)) {
rtllib_start_scan_syncro(ieee, 0);
@@ -412,7 +411,6 @@ void rtllib_wx_sync_scan_wq(void *data)
rtllib_wake_all_queues(ieee);
- count = 0;
out:
up(&ieee->wx_sem); |
int b40M = 0;
- static int count;
- count = 0;
out:
up(&ieee->wx_sem);
