staging: rtl8192e: Remove unnecessary OOM message
Author: Quentin Lambert <lambert.quentin@gmail.com>
This patch reduces the kernel size by removing error messages that duplicate
the normal OOM message.
A simplified version of the semantic patch that finds this problem is as
follows: (http://coccinelle.lip6.fr)
identifier f,print,l;
expression e;
constant char[] c;
e = \(kzalloc\|kmalloc\|devm_kzalloc\|devm_kmalloc\)(...);
if (e == NULL) {
-  print(...,c,...);
  ... when any
  goto l;
  return ...;
Signed-off-by: Quentin Lambert
 drivers/staging/rtl8192e/rtllib_module.c | 10 +++-------
 drivers/staging/rtl8192e/rtllib_rx.c     | 11 ++++-------
 2 files changed, 7 insertions(+), 14 deletions(-)
diff --git a/drivers/staging/rtl8192e/rtllib_module.c b/drivers/staging/rtl8192e/rtllib_module.c
index 248cc0d..32cc8df 100644
--- a/drivers/staging/rtl8192e/rtllib_module.c
+++ b/drivers/staging/rtl8192e/rtllib_module.c
@@ -72,11 +72,8 @@ static inline int rtllib_networks_allocate(struct rtllib_device *ieee)
 	ieee->networks = kzalloc(
 		MAX_NETWORK_COUNT * sizeof(struct rtllib_network),
 		GFP_KERNEL);
-	if (!ieee->networks) {
-		printk(KERN_WARNING "%s: Out of memory allocating beacons\n",
-		       ieee->dev->name);
+	if (!ieee->networks)
 		return -ENOMEM;
 	return 0;
@@ -161,10 +158,9 @@ struct net_device *alloc_rtllib(int sizeof_priv)
 	rtllib_softmac_init(ieee);
 	ieee->pHTInfo = kzalloc(sizeof(struct rt_hi_throughput), GFP_KERNEL);
-	if (ieee->pHTInfo == NULL) {
-		RTLLIB_DEBUG(RTLLIB_DL_ERR, "can't alloc memory for HTInfo\n");
+	if (ieee->pHTInfo == NULL)
 		return NULL;
 	HTUpdateDefaultSetting(ieee);
 	HTInitializeHTInfo(ieee);
 	TSInitialize(ieee);
diff --git a/drivers/staging/rtl8192e/rtllib_rx.c b/drivers/staging/rtl8192e/rtllib_rx.c
index 1664040..0a9cf44 100644
--- a/drivers/staging/rtl8192e/rtllib_rx.c
+++ b/drivers/staging/rtl8192e/rtllib_rx.c
@@ -394,10 +394,9 @@ static int is_duplicate_packet(struct rtllib_device *ieee,
 		if (p == &ieee->ibss_mac_hash[index]) {
 			entry = kmalloc(sizeof(struct ieee_ibss_seq), GFP_ATOMIC);
-			if (!entry) {
-				printk(KERN_WARNING "Cannot malloc new mac entry\n");
+			if (!entry)
 				return 0;
 			memcpy(entry->mac, mac, ETH_ALEN);
 			entry->seq_num[tid] = seq;
 			entry->frag_num[tid] = frag;
@@ -1345,11 +1344,9 @@ static int rtllib_rx_InfraAdhoc(struct rtllib_device *ieee, struct sk_buff *skb,
 	/* skb: hdr + (possible reassembled) full plaintext payload */
 	payload = skb->data + hdrlen;
 	rxb = kmalloc(sizeof(struct rtllib_rxb), GFP_ATOMIC);
-	if (rxb == NULL) {
-			     "%s(): kmalloc rxb error\n", __func__);
+	if (rxb == NULL)
 		goto rx_dropped;
 	/* to parse amsdu packets */
 	/* qos data packets & reserved bit is 1 */
 	if (parse_subframe(ieee, skb, rx_stats, rxb, src, dst) == 0) {
BtrLinux
Privacy Overview
