drivers/staging/comedi/drivers/cb_pcidas64.c | 6 ++---
drivers/staging/comedi/drivers/ni_mio_common.c | 36 ++++++++++----------------
2 files changed, 15 insertions(+), 27 deletions(-)
diff --git a/drivers/staging/comedi/drivers/cb_pcidas64.c b/drivers/staging/comedi/drivers/cb_pcidas64.c
index 551e9d9..bd24059 100644
--- a/drivers/staging/comedi/drivers/cb_pcidas64.c
+++ b/drivers/staging/comedi/drivers/cb_pcidas64.c
@@ -1703,8 +1703,7 @@ static void i2c_write(struct comedi_device *dev, unsigned int address,
/* get acknowledge */
if (i2c_read_ack(dev) != 0) {
- dev_err(dev->class_dev, "%s failed: no acknowledge\n",
- __func__);
+ dev_err(dev->class_dev, "failed: no acknowledge\n");
i2c_stop(dev);
return;
@@ -1712,8 +1711,7 @@ static void i2c_write(struct comedi_device *dev, unsigned int address,
for (i = 0; i < length; i++) {
i2c_write_byte(dev, data[i]);
- __func__);
i2c_stop(dev);
return;
diff --git a/drivers/staging/comedi/drivers/ni_mio_common.c b/drivers/staging/comedi/drivers/ni_mio_common.c
index b6ddc01..176b64a 100644
--- a/drivers/staging/comedi/drivers/ni_mio_common.c
+++ b/drivers/staging/comedi/drivers/ni_mio_common.c
@@ -1068,7 +1068,7 @@ static int ni_ai_drain_dma(struct comedi_device *dev)
udelay(5);
if (i == timeout) {
- dev_err(dev->class_dev, "%s timed out\n", __func__);
+ dev_err(dev->class_dev, "timed out\n");
"mite_bytes_in_transit=%i, AI_Status1_Register=0x%x\n",
mite_bytes_in_transit(devpriv->ai_mite_chan),
@@ -2116,8 +2116,7 @@ static int ni_ai_insn_read(struct comedi_device *dev,
if (i == NI_TIMEOUT) {
- dev_err(dev->class_dev, "%s timeout\n",
- __func__);
+ dev_err(dev->class_dev, "timeout\n");
return -ETIME;
d += signbits;
@@ -2140,8 +2139,7 @@ static int ni_ai_insn_read(struct comedi_device *dev,
- __func__);
return -ETIME;
data[n] = (((dl >> 16) & 0xFFFF) + signbits) & 0xFFFF;
@@ -2156,8 +2154,7 @@ static int ni_ai_insn_read(struct comedi_device *dev,
break;
- __func__);
return -ETIME;
if (devpriv->is_m_series) {
@@ -2808,8 +2805,7 @@ static int ni_m_series_ao_config_chanlist(struct comedi_device *dev,
break;
default:
- "%s: bug! unhandled ao reference voltage\n",
- __func__);
+ "bug! unhandled ao reference voltage\n");
break;
switch (krange->max + krange->min) {
@@ -2821,8 +2817,7 @@ static int ni_m_series_ao_config_chanlist(struct comedi_device *dev,
break;
default:
- "%s: bug! unhandled ao offset voltage\n",
- __func__);
+ "bug! unhandled ao offset voltage\n");
break;
if (timed)
@@ -3694,8 +3689,7 @@ static int ni_serial_hw_readwrite8(struct comedi_device *dev,
udelay((devpriv->serial_interval_ns + 999) / 1000);
if (--count < 0) {
- "%s: SPI serial I/O didn't finish in time!\n",
- __func__);
+ "SPI serial I/O didn't finish in time!\n");
err = -ETIME;
goto Error;
@@ -3833,8 +3827,7 @@ static int ni_serial_insn_config(struct comedi_device *dev,
err = ni_serial_sw_readwrite8(dev, s, byte_out,
&byte_in);
} else {
- dev_err(dev->class_dev, "%s: serial disabled!\n",
- __func__);
+ dev_err(dev->class_dev, "serial disabled!\n");
return -EINVAL;
if (err < 0)
@@ -4520,8 +4513,7 @@ static unsigned ni_old_get_pfi_routing(struct comedi_device *dev,
case 9:
return NI_PFI_OUTPUT_G_GATE0;
default:
- "%s: bug, unhandled case in switch.\n", __func__);
+ dev_err(dev->class_dev, "bug, unhandled case in switch.\n");
break;
return 0;
@@ -4673,7 +4665,7 @@ static int cs5529_wait_for_idle(struct comedi_device *dev)
return -EIO;
if (i == timeout) {
- dev_err(dev->class_dev, "%s timeout\n", __func__);
return -ETIME;
return 0;
@@ -4908,7 +4900,7 @@ static int ni_mseries_set_pll_master_clock(struct comedi_device *dev,
&devpriv->clock_ns);
if (retval < 0) {
- "%s: bug, failed to find pll parameters\n", __func__);
+ "bug, failed to find pll parameters\n");
return retval;
@@ -4966,8 +4958,7 @@ static int ni_set_master_clock(struct comedi_device *dev,
RTSI_Trig_Direction_Register);
if (period_ns == 0) {
- "%s: we don't handle an unspecified clock period correctly yet, returning error\n",
- __func__);
+ "we don't handle an unspecified clock period correctly yet, returning error\n");
return -EINVAL;
devpriv->clock_ns = period_ns;
@@ -5057,8 +5048,7 @@ static unsigned ni_get_rtsi_routing(struct comedi_device *dev, unsigned chan)
} else {
if (chan == old_RTSI_clock_channel)
return NI_RTSI_OUTPUT_RTSI_OSC;
- dev_err(dev->class_dev, "%s: bug! should never get here?\n",
- __func__);
+ dev_err(dev->class_dev, "bug! should never get here?\n");
return 0;
