staging: rtl8188eu: rtw_mlme_ext: Clean up tests if NULL returned on failure
Author: Bhaktipriya Shridhar <bhaktipriya96@gmail.com>
Some functions like kzalloc return NULL on failure.
When NULL represents failure, !x is commonly used.
This was done using Coccinelle:
expression *e;
identifier l1;
e = \(kmalloc\|kzalloc\|kcalloc\|devm_kzalloc\)(...);
- e == NULL
+ !e
Signed-off-by: Bhaktipriya Shridhar
 drivers/staging/rtl8188eu/core/rtw_mlme_ext.c | 26 +++++++++++++-------------
 1 file changed, 13 insertions(+), 13 deletions(-)
diff --git a/drivers/staging/rtl8188eu/core/rtw_mlme_ext.c b/drivers/staging/rtl8188eu/core/rtw_mlme_ext.c
index 86108d4..439c035 100644
--- a/drivers/staging/rtl8188eu/core/rtw_mlme_ext.c
+++ b/drivers/staging/rtl8188eu/core/rtw_mlme_ext.c
@@ -4289,12 +4289,12 @@ void report_survey_event(struct adapter *padapter,
 	pcmd_obj = kzalloc(sizeof(struct cmd_obj), GFP_ATOMIC);
-	if (pcmd_obj == NULL)
+	if (!pcmd_obj)
 		return;
 	cmdsz = sizeof(struct survey_event) + sizeof(struct C2HEvent_Header);
 	pevtcmd = kzalloc(cmdsz, GFP_ATOMIC);
-	if (pevtcmd == NULL) {
+	if (!pevtcmd) {
 		kfree(pcmd_obj);
 		return;
@@ -4341,12 +4341,12 @@ void report_surveydone_event(struct adapter *padapter)
 	struct cmd_priv *pcmdpriv = &padapter->cmdpriv;
 	pcmd_obj = kzalloc(sizeof(struct cmd_obj), GFP_KERNEL);
+	if (!pcmd_obj)
 		return;
 	cmdsz = sizeof(struct surveydone_event) + sizeof(struct C2HEvent_Header);
 	pevtcmd = kzalloc(cmdsz, GFP_KERNEL);
+	if (!pevtcmd) {
 		kfree(pcmd_obj);
 		return;
@@ -4387,12 +4387,12 @@ void report_join_res(struct adapter *padapter, int res)
+	if (!pcmd_obj)
 		return;
 	cmdsz = sizeof(struct joinbss_event) + sizeof(struct C2HEvent_Header);
+	if (!pevtcmd) {
 		kfree(pcmd_obj);
 		return;
@@ -4440,12 +4440,12 @@ void report_del_sta_event(struct adapter *padapter, unsigned char *MacAddr, unsi
+	if (!pcmd_obj)
 		return;
 	cmdsz = sizeof(struct stadel_event) + sizeof(struct C2HEvent_Header);
+	if (!pevtcmd) {
 		kfree(pcmd_obj);
 		return;
@@ -4495,12 +4495,12 @@ void report_add_sta_event(struct adapter *padapter, unsigned char *MacAddr, int
+	if (!pcmd_obj)
 		return;
 	cmdsz = sizeof(struct stassoc_event) + sizeof(struct C2HEvent_Header);
+	if (!pevtcmd) {
 		kfree(pcmd_obj);
 		return;
@@ -4911,11 +4911,11 @@ void survey_timer_hdl(unsigned long data)
 		ph2c = kzalloc(sizeof(struct cmd_obj), GFP_ATOMIC);
-		if (ph2c == NULL)
+		if (!ph2c)
 			goto exit_survey_timer_hdl;
 		psurveyPara = kzalloc(sizeof(struct sitesurvey_parm), GFP_ATOMIC);
-		if (psurveyPara == NULL) {
+		if (!psurveyPara) {
 			kfree(ph2c);
@@ -5479,7 +5479,7 @@ u8 set_tx_beacon_cmd(struct adapter *padapter)
 	ph2c = kzalloc(sizeof(struct cmd_obj), GFP_KERNEL);
-	if (ph2c == NULL) {
+	if (!ph2c) {
 		res = _FAIL;
 		goto exit;
BtrLinux
Privacy Overview
