staging: rtl8188eu: core: rtw_mlme: Clean up tests if NULL returned on failure
Author: Bhaktipriya Shridhar <bhaktipriya96@gmail.com>
Some functions like kmalloc/kzalloc return NULL on failure.
When NULL represents failure, !x is commonly used.
This was done using Coccinelle:
expression *e;
identifier l1;
e = \(kmalloc\|kzalloc\|kcalloc\|devm_kzalloc\)(...);
- e == NULL
+ !e
Signed-off-by: Bhaktipriya Shridhar
drivers/staging/rtl8188eu/core/rtw_mlme.c | 8 ++++----
1 file changed, 4 insertions(+), 4 deletions(-)
diff --git a/drivers/staging/rtl8188eu/core/rtw_mlme.c b/drivers/staging/rtl8188eu/core/rtw_mlme.c
index 472cd3f..1456499 100644
--- a/drivers/staging/rtl8188eu/core/rtw_mlme.c
+++ b/drivers/staging/rtl8188eu/core/rtw_mlme.c
@@ -1579,13 +1579,13 @@ int rtw_set_auth(struct adapter *adapter, struct security_priv *psecuritypriv)
int res = _SUCCESS;
pcmd = kzalloc(sizeof(struct cmd_obj), GFP_KERNEL);
- if (pcmd == NULL) {
+ if (!pcmd) {
res = _FAIL; /* try again */
goto exit;
psetauthparm = kzalloc(sizeof(struct setauth_parm), GFP_KERNEL);
- if (psetauthparm == NULL) {
+ if (!psetauthparm) {
kfree(pcmd);
res = _FAIL;
goto exit;
@@ -1616,11 +1616,11 @@ int rtw_set_key(struct adapter *adapter, struct security_priv *psecuritypriv, in
int res = _SUCCESS;
- if (pcmd == NULL)
+ if (!pcmd)
return _FAIL; /* try again */
psetkeyparm = kzalloc(sizeof(struct setkey_parm), GFP_KERNEL);
- if (psetkeyparm == NULL) {
+ if (!psetkeyparm) {
res = _FAIL;
goto err_free_cmd;
int res = _SUCCESS;
+ if (!pcmd) {
goto exit;
kfree(pcmd);
res = _FAIL;
goto exit;
int res = _SUCCESS;
- if (pcmd == NULL)
+ if (!pcmd)
res = _FAIL;
goto err_free_cmd;
