Staging: rtl8188eu: Remove redundant local variable
Author: Somya Anand <somyaanand214@gmail.com>
This patch removes a redundant variable "val" and adds
inline return statements. It also adds a default case
to the switch statement which returns 0 to keep the logic
intact.
It also removes a redundant variable "inx" and adds inline
return statements.
This issue is identified by the following coccinelle script.
expression ret;
identifier f;
-ret =
+return
     f(...);
-return ret;
Signed-off-by: Somya Anand
 drivers/staging/rtl8188eu/core/rtw_wlan_util.c | 81 +++++++++-----------------
 1 file changed, 28 insertions(+), 53 deletions(-)
diff --git a/drivers/staging/rtl8188eu/core/rtw_wlan_util.c b/drivers/staging/rtl8188eu/core/rtw_wlan_util.c
index 509fc05..9e9645b 100644
--- a/drivers/staging/rtl8188eu/core/rtw_wlan_util.c
+++ b/drivers/staging/rtl8188eu/core/rtw_wlan_util.c
@@ -136,47 +136,34 @@ u8 judge_network_type(struct adapter *padapter, unsigned char *rate, int ratelen
 static unsigned char ratetbl_val_2wifirate(unsigned char rate)
-	unsigned char val = 0;
 	switch (rate & 0x7f) {
 	case 0:
-		val = IEEE80211_CCK_RATE_1MB;
-		break;
+		return IEEE80211_CCK_RATE_1MB;
 	case 1:
-		val = IEEE80211_CCK_RATE_2MB;
-		break;
+		return IEEE80211_CCK_RATE_2MB;
 	case 2:
-		val = IEEE80211_CCK_RATE_5MB;
-		break;
+		return IEEE80211_CCK_RATE_5MB;
 	case 3:
-		val = IEEE80211_CCK_RATE_11MB;
-		break;
+		return IEEE80211_CCK_RATE_11MB;
 	case 4:
-		val = IEEE80211_OFDM_RATE_6MB;
-		break;
+		return IEEE80211_OFDM_RATE_6MB;
 	case 5:
-		val = IEEE80211_OFDM_RATE_9MB;
-		break;
+		return IEEE80211_OFDM_RATE_9MB;
 	case 6:
-		val = IEEE80211_OFDM_RATE_12MB;
-		break;
+		return IEEE80211_OFDM_RATE_12MB;
 	case 7:
-		val = IEEE80211_OFDM_RATE_18MB;
-		break;
+		return IEEE80211_OFDM_RATE_18MB;
 	case 8:
-		val = IEEE80211_OFDM_RATE_24MB;
-		break;
+		return IEEE80211_OFDM_RATE_24MB;
 	case 9:
-		val = IEEE80211_OFDM_RATE_36MB;
-		break;
+		return IEEE80211_OFDM_RATE_36MB;
 	case 10:
-		val = IEEE80211_OFDM_RATE_48MB;
-		break;
+		return IEEE80211_OFDM_RATE_48MB;
 	case 11:
-		val = IEEE80211_OFDM_RATE_54MB;
-		break;
+		return IEEE80211_OFDM_RATE_54MB;
+	default:
+		return 0;
-	return val;
 static int is_basicrate(struct adapter *padapter, unsigned char rate)
@@ -1209,48 +1196,36 @@ unsigned int is_ap_in_wep(struct adapter *padapter)
 static int wifirate2_ratetbl_inx(unsigned char rate)
-	int	inx = 0;
 	rate = rate & 0x7f;
 	switch (rate) {
 	case 54*2:
-		inx = 11;
-		break;
+		return 11;
 	case 48*2:
-		inx = 10;
-		break;
+		return 10;
 	case 36*2:
-		inx = 9;
-		break;
+		return 9;
 	case 24*2:
-		inx = 8;
-		break;
+		return 8;
 	case 18*2:
-		inx = 7;
-		break;
+		return 7;
 	case 12*2:
-		inx = 6;
-		break;
+		return 6;
 	case 9*2:
-		inx = 5;
-		break;
+		return 5;
 	case 6*2:
-		inx = 4;
-		break;
+		return 4;
 	case 11*2:
-		inx = 3;
-		break;
+		return 3;
 	case 11:
-		inx = 2;
-		break;
+		return 2;
 	case 2*2:
-		inx = 1;
-		break;
+		return 1;
 	case 1*2:
-		inx = 0;
-		break;
+		return 0;
+	default:
+		return 0;
-	return inx;
 unsigned int update_basic_rate(unsigned char *ptn, unsigned int ptn_sz)
BtrLinux
Privacy Overview
