drivers: staging: iio: meter: Removed unnecessary variable
Author: Tina Johnson <tinajohnson.1234@gmail.com>
Variable ret is used only to store the return value. Hence ret is
removed and the return statement modified. Coccinelle was used to
detect such removable variables:
@rule1@
identifier ret;
expression e;
-ret =
+return
           e;
-return ret;
Signed-off-by: Tina Johnson
 drivers/staging/iio/meter/ade7854-spi.c | 6 +-----
 1 file changed, 1 insertion(+), 5 deletions(-)
diff --git a/drivers/staging/iio/meter/ade7854-spi.c b/drivers/staging/iio/meter/ade7854-spi.c
index 94f73bb..9b255a5 100644
--- a/drivers/staging/iio/meter/ade7854-spi.c
+++ b/drivers/staging/iio/meter/ade7854-spi.c
@@ -274,7 +274,6 @@ error_ret:
 static int ade7854_spi_probe(struct spi_device *spi)
-	int ret;
 	struct ade7854_state *st;
 	struct iio_dev *indio_dev;
@@ -294,10 +293,7 @@ static int ade7854_spi_probe(struct spi_device *spi)
 	st->irq = spi->irq;
 	st->spi = spi;
-	ret = ade7854_probe(indio_dev, &spi->dev);
-	return ret;
+	return ade7854_probe(indio_dev, &spi->dev);
 static int ade7854_spi_remove(struct spi_device *spi)
