staging: rtl8188eu: core: Use put_unaligned_le16
Author: Amitoj Kaur Chawla <amitoj1606@gmail.com>
Introduce the use of function put_unaligned_le16.
This is done using the following Coccinelle semantic patch:
@@ identifier tmp; expression ptr; expression y,e; type T; @@
- tmp = cpu_to_le16(y);
  <+... when != tmp
- memcpy(ptr, (T)&tmp, ...);
+ put_unaligned_le16(y,ptr);
? tmp = e
@@ type T; identifier tmp; @@
- T tmp;
...when != tmp
Corresponding header file has been added too.
Signed-off-by: Amitoj Kaur Chawla
 drivers/staging/rtl8188eu/core/rtw_mlme_ext.c | 5 ++---
 1 file changed, 2 insertions(+), 3 deletions(-)
diff --git a/drivers/staging/rtl8188eu/core/rtw_mlme_ext.c b/drivers/staging/rtl8188eu/core/rtw_mlme_ext.c
index 96e5c6d..e3add48 100644
--- a/drivers/staging/rtl8188eu/core/rtw_mlme_ext.c
+++ b/drivers/staging/rtl8188eu/core/rtw_mlme_ext.c
@@ -20,6 +20,7 @@
 #define _RTW_MLME_EXT_C_
 #include <linux/ieee80211.h>
+#include <asm/unaligned.h>
 #include <osdep_service.h>
 #include <drv_types.h>
@@ -1027,7 +1028,6 @@ static void issue_assocreq(struct adapter *padapter)
 	unsigned char		*pframe, *p;
 	struct rtw_ieee80211_hdr	*pwlanhdr;
 	__le16 *fctrl;
-	__le16		le_tmp;
 	unsigned int	i, j, ie_len, index = 0;
 	unsigned char	rf_type, bssrate[NumRates], sta_bssrate[NumRates];
 	struct ndis_802_11_var_ie *pIE;
@@ -1073,8 +1073,7 @@ static void issue_assocreq(struct adapter *padapter)
 	/* listen interval */
 	/* todo: listen interval for power saving */
-	le_tmp = cpu_to_le16(3);
-	memcpy(pframe , (unsigned char *)&le_tmp, 2);
+	put_unaligned_le16(3, pframe);
 	pframe += 2;
 	pattrib->pktlen += 2;
BtrLinux
Privacy Overview
