Staging: lustre: lov: Pull assignments out of function call
Author: Bhumika Goyal <bhumirks@gmail.com>
Assignments in function call arguments are undesirable. So pull such
assignments out before function call.
Made a coccinelle script to detect such cases:
expression fn,b,d;
* fn(...,d=b,...);
Signed-off-by: Bhumika Goyal
drivers/staging/lustre/lustre/lov/lov_merge.c | 3 ++-
1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/drivers/staging/lustre/lustre/lov/lov_merge.c b/drivers/staging/lustre/lustre/lov/lov_merge.c
index 97115be..029cd4d 100644
--- a/drivers/staging/lustre/lustre/lov/lov_merge.c
+++ b/drivers/staging/lustre/lustre/lov/lov_merge.c
@@ -129,7 +129,8 @@ int lov_adjust_kms(struct obd_export *exp, struct lov_stripe_md *lsm,
"stripe %d KMS %sing %llu->%llu\n",
stripe, kms > loi->loi_kms ? "increase":"shrink",
loi->loi_kms, kms);
- loi_kms_set(loi, loi->loi_lvb.lvb_size = kms);
+ loi->loi_lvb.lvb_size = kms;
+ loi_kms_set(loi, loi->loi_lvb.lvb_size);
return 0;
loi->loi_kms, kms);
return 0;
