staging: rdma: hfi1: Use offset_in_page macro
Author: Amitoj Kaur Chawla <amitoj1606@gmail.com>
Use offset_in_page macro instead of (var & ~PAGE_MASK)
The Coccinelle semantic patch used to make this change is as follows:
unsigned long p;
- p & ~PAGE_MASK
+ offset_in_page(p)
Signed-off-by: Amitoj Kaur Chawla
drivers/staging/rdma/hfi1/user_sdma.c | 4 ++--
1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/staging/rdma/hfi1/user_sdma.c b/drivers/staging/rdma/hfi1/user_sdma.c
index 4f55950..feb2069 100644
--- a/drivers/staging/rdma/hfi1/user_sdma.c
+++ b/drivers/staging/rdma/hfi1/user_sdma.c
@@ -925,8 +925,8 @@ static int user_sdma_send_pkts(struct user_sdma_request *req, unsigned maxpkts)
unsigned pageidx, len;
base = (unsigned long)iovec->iov.iov_base;
- offset = ((base + iovec->offset + iov_offset) &
- ~PAGE_MASK);
+ offset = offset_in_page(base + iovec->offset +
+ iov_offset);
pageidx = (((iovec->offset + iov_offset +
base) - (base & PAGE_MASK)) >> PAGE_SHIFT);
len = offset + req->info.fragsize > PAGE_SIZE ? |
- ~PAGE_MASK);
+ iov_offset);
