drivers/staging/wilc1000/wilc_sdio.c | 8 ++++----
drivers/staging/wilc1000/wilc_spi.c | 8 ++++----
drivers/staging/wilc1000/wilc_wlan_cfg.c | 10 +++++-----
3 files changed, 13 insertions(+), 13 deletions(-)
diff --git a/drivers/staging/wilc1000/wilc_sdio.c b/drivers/staging/wilc1000/wilc_sdio.c
index 963875af..029bd09 100644
--- a/drivers/staging/wilc1000/wilc_sdio.c
+++ b/drivers/staging/wilc1000/wilc_sdio.c
@@ -30,15 +30,15 @@ static const struct sdio_device_id wilc_sdio_ids[] = {
#define WILC_SDIO_BLOCK_SIZE 512
-typedef struct {
+struct wilc_sdio {
bool irq_gpio;
u32 block_size;
int nint;
#define MAX_NUN_INT_THRPT_ENH2 (5) /* Max num interrupts allowed in registers 0xf7, 0xf8 */
int has_thrpt_enh3;
-} wilc_sdio_t;
-static wilc_sdio_t g_sdio;
+static struct wilc_sdio g_sdio;
static int sdio_write_reg(struct wilc *wilc, u32 addr, u32 data);
static int sdio_read_reg(struct wilc *wilc, u32 addr, u32 *data);
@@ -675,7 +675,7 @@ static int sdio_init(struct wilc *wilc, bool resume)
u32 chipid;
if (!resume) {
- memset(&g_sdio, 0, sizeof(wilc_sdio_t));
+ memset(&g_sdio, 0, sizeof(struct wilc_sdio));
g_sdio.irq_gpio = wilc->dev_irq_num;
diff --git a/drivers/staging/wilc1000/wilc_spi.c b/drivers/staging/wilc1000/wilc_spi.c
index cfec982..b55a0c3f 100644
--- a/drivers/staging/wilc1000/wilc_spi.c
+++ b/drivers/staging/wilc1000/wilc_spi.c
@@ -24,13 +24,13 @@
#include "wilc_wlan.h"
#include "wilc_wfi_netdevice.h"
-typedef struct {
+struct wilc_spi {
int crc_off;
int nint;
int has_thrpt_enh;
-} wilc_spi_t;
-static wilc_spi_t g_spi;
+static struct wilc_spi g_spi;
static int wilc_spi_read(struct wilc *wilc, u32, u8 *, u32);
static int wilc_spi_write(struct wilc *wilc, u32, u8 *, u32);
@@ -861,7 +861,7 @@ static int wilc_spi_init(struct wilc *wilc, bool resume)
return 1;
- memset(&g_spi, 0, sizeof(wilc_spi_t));
+ memset(&g_spi, 0, sizeof(struct wilc_spi));
* configure protocol
diff --git a/drivers/staging/wilc1000/wilc_wlan_cfg.c b/drivers/staging/wilc1000/wilc_wlan_cfg.c
index 9dab247..56455f4 100644
--- a/drivers/staging/wilc1000/wilc_wlan_cfg.c
+++ b/drivers/staging/wilc1000/wilc_wlan_cfg.c
@@ -19,7 +19,7 @@
-typedef struct {
+struct wilc_mac_cfg {
wilc_debug_func dPrint;
int mac_status;
@@ -40,9 +40,9 @@ typedef struct {
u8 firmware_info[8];
u8 scan_result[256];
u8 scan_result1[256];
-} wilc_mac_cfg_t;
-static wilc_mac_cfg_t g_mac;
+static struct wilc_mac_cfg g_mac;
static struct wilc_cfg_byte g_cfg_byte[] = {
{WID_BSS_TYPE, 0},
@@ -349,7 +349,7 @@ static void wilc_wlan_parse_response_frame(u8 *info, int size)
static int wilc_wlan_parse_info_frame(u8 *info, int size)
- wilc_mac_cfg_t *pd = &g_mac;
+ struct wilc_mac_cfg *pd = &g_mac;
u32 wid, len;
int type = WILC_CFG_RSP_STATUS;
@@ -539,7 +539,7 @@ int wilc_wlan_cfg_indicate_rx(struct wilc *wilc, u8 *frame, int size,
int wilc_wlan_cfg_init(wilc_debug_func func)
- memset((void *)&g_mac, 0, sizeof(wilc_mac_cfg_t));
+ memset((void *)&g_mac, 0, sizeof(struct wilc_mac_cfg));
g_mac.dPrint = func;
return 1;
