staging: ozwpan: Remove useless return variables
Author: Peter Senna Tschudin <peter.senna@gmail.com>
This patch remove variables that are initialized with a constant,
are never updated, and are only used as parameter of return.
Return the constant instead of using a variable.
Verified by compilation only.
The coccinelle script that find and fixes this issue is:
type T;
constant C;
identifier ret;
- T ret = C;
... when != ret
- return ret;
+ return C;
Signed-off-by: Peter Senna Tschudin
 drivers/staging/ozwpan/ozhcd.c | 6 ++----
 1 file changed, 2 insertions(+), 4 deletions(-)
diff --git a/drivers/staging/ozwpan/ozhcd.c b/drivers/staging/ozwpan/ozhcd.c
index 91bb29e..30bd928 100644
--- a/drivers/staging/ozwpan/ozhcd.c
+++ b/drivers/staging/ozwpan/ozhcd.c
@@ -2011,7 +2011,6 @@ static void oz_get_hub_descriptor(struct usb_hcd *hcd,
 static int oz_set_port_feature(struct usb_hcd *hcd, u16 wvalue, u16 windex)
 	struct oz_port *port;
-	int err = 0;
 	u8 port_id = (u8)windex;
 	struct oz_hcd *ozhcd = oz_hcd_private(hcd);
 	unsigned set_bits = 0;
@@ -2078,7 +2077,7 @@ static int oz_set_port_feature(struct usb_hcd *hcd, u16 wvalue, u16 windex)
 		spin_unlock_bh(&port->port_lock);
 	oz_dbg(HUB, "Port[%d] status = 0x%x\n", port_id, port->status);
-	return err;
+	return 0;
@@ -2087,7 +2086,6 @@ static int oz_set_port_feature(struct usb_hcd *hcd, u16 wvalue, u16 windex)
 static int oz_clear_port_feature(struct usb_hcd *hcd, u16 wvalue, u16 windex)
-	int err = 0;
 	unsigned clear_bits = 0;
@@ -2154,7 +2152,7 @@ static int oz_clear_port_feature(struct usb_hcd *hcd, u16 wvalue, u16 windex)
 	       port_id, ozhcd->ports[port_id-1].status);
-	return err;
+	return 0;
BtrLinux
Privacy Overview
