staging: msm/lcdc.c: Convert IS_ERR result to PTR_ERR
This code elsewhere returns a negative constant to an indicate an error,
while IS_ERR returns the result of a >= operation.
The semantic patch that fixes this problem is as follows:
(http://coccinelle.lip6.fr/)
expression x;
 if (...) { ...
- return IS_ERR(x);
+ return PTR_ERR(x);
Signed-off-by: Julia Lawall
Acked-by: David Brown
 drivers/staging/msm/lcdc.c | 4 ++--
 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/staging/msm/lcdc.c b/drivers/staging/msm/lcdc.c
index 735280a..8183394 100644
--- a/drivers/staging/msm/lcdc.c
+++ b/drivers/staging/msm/lcdc.c
@@ -224,12 +224,12 @@ static int __init lcdc_driver_init(void)
 	mdp_lcdc_pclk_clk = clk_get(NULL, "mdp_lcdc_pclk_clk");
 	if (IS_ERR(mdp_lcdc_pclk_clk)) {
 		printk(KERN_ERR "error: can't get mdp_lcdc_pclk_clk!\n");
-		return IS_ERR(mdp_lcdc_pclk_clk);
+		return PTR_ERR(mdp_lcdc_pclk_clk);
 	mdp_lcdc_pad_pclk_clk = clk_get(NULL, "mdp_lcdc_pad_pclk_clk");
 	if (IS_ERR(mdp_lcdc_pad_pclk_clk)) {
 		printk(KERN_ERR "error: can't get mdp_lcdc_pad_pclk_clk!\n");
-		return IS_ERR(mdp_lcdc_pad_pclk_clk);
+		return PTR_ERR(mdp_lcdc_pad_pclk_clk);
 //	pm_qos_add_requirement(PM_QOS_SYSTEM_BUS_FREQ , "lcdc",
 //				PM_QOS_DEFAULT_VALUE);
BtrLinux
Privacy Overview
