arch/arm/mach-omap2/dma.c: Convert IS_ERR result to PTR_ERR
This code elsewhere returns a negative constant to an indicate an error,
while IS_ERR returns the result of a >= operation.
The semantic patch that fixes this problem is as follows:
(http://coccinelle.lip6.fr/)
expression x;
if (...) { ...
- return IS_ERR(x);
+ return PTR_ERR(x);
Signed-off-by: Julia Lawall
Acked-by: Jarkko Nikula
Signed-off-by: Tony Lindgren
arch/arm/mach-omap2/dma.c | 2 +-
1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/arm/mach-omap2/dma.c b/arch/arm/mach-omap2/dma.c
index d2f15f5..34922b2 100644
--- a/arch/arm/mach-omap2/dma.c
+++ b/arch/arm/mach-omap2/dma.c
@@ -264,7 +264,7 @@ static int __init omap2_system_dma_init_dev(struct omap_hwmod *oh, void *unused)
if (IS_ERR(od)) {
pr_err("%s: Cant build omap_device for %s:%s.\n",
__func__, name, oh->name);
- return IS_ERR(od);
+ return PTR_ERR(od);
mem = platform_get_resource(&od->pdev, IORESOURCE_MEM, 0); |
if (IS_ERR(od)) {
