staging: media: bcm2048: remove extra parentheses around right bit shift operation
Author: Aya Mahfouz <mahfouz.saif.elyazal@gmail.com>
Removes extra parentheses around bitwise right shift operation.
The case handled here is when the resultant value is assigned to
a variable. The issue was detected and resolved using the following
coccinelle script:
expression e, e1;
constant c;
e =
-(e1
+e1
-c);
+c;
identifier i;
constant c;
type t;
expression e;
t i =
-(e
+e
-c);
+c;
expression e, e1;
identifier f;
constant c;
e1 = f(...,
-(e
+e
-c)
+c
Signed-off-by: Aya Mahfouz
 drivers/staging/media/bcm2048/radio-bcm2048.c | 3 +--
 1 file changed, 1 insertion(+), 2 deletions(-)
diff --git a/drivers/staging/media/bcm2048/radio-bcm2048.c b/drivers/staging/media/bcm2048/radio-bcm2048.c
index 5382506..116251b 100644
--- a/drivers/staging/media/bcm2048/radio-bcm2048.c
+++ b/drivers/staging/media/bcm2048/radio-bcm2048.c
@@ -2245,8 +2245,7 @@ static ssize_t bcm2048_fops_read(struct file *file, char __user *buf,
 		tmpbuf[i] = bdev->rds_info.radio_text[bdev->rd_index+i+2];
 		tmpbuf[i+1] = bdev->rds_info.radio_text[bdev->rd_index+i+1];
-		tmpbuf[i+2] = ((bdev->rds_info.radio_text[bdev->rd_index+i]
-				& 0xf0) >> 4);
+		tmpbuf[i+2] = (bdev->rds_info.radio_text[bdev->rd_index + i] & 0xf0) >> 4;
 		if ((bdev->rds_info.radio_text[bdev->rd_index+i] &
 			BCM2048_RDS_CRC_MASK) == BCM2048_RDS_CRC_UNRECOVARABLE)
 			tmpbuf[i+2] |= 0x80;
BtrLinux
Privacy Overview
