staging: lustre: llite: remove extra parentheses around right bit shift operation
Author: Aya Mahfouz <mahfouz.saif.elyazal@gmail.com>
Removes extra parentheses around bitwise right shift operation.
The case handled here is when the resultant value is assigned to
a variable. The issue was detected and resolved using the following
coccinelle script:
expression e, e1;
constant c;
e =
-(e1
+e1
-c);
+c;
identifier i;
constant c;
type t;
expression e;
t i =
-(e
+e
-c);
+c;
expression e, e1;
identifier f;
constant c;
e1 = f(...,
-(e
+e
-c)
+c
Signed-off-by: Aya Mahfouz
 drivers/staging/lustre/lustre/llite/vvp_dev.c | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/staging/lustre/lustre/llite/vvp_dev.c b/drivers/staging/lustre/lustre/llite/vvp_dev.c
index 5a1078a..97d94fc 100644
--- a/drivers/staging/lustre/lustre/llite/vvp_dev.c
+++ b/drivers/staging/lustre/lustre/llite/vvp_dev.c
@@ -286,7 +286,7 @@ static void vvp_pgcache_id_unpack(loff_t pos, struct vvp_pgcache_id *id)
 	id->vpi_index  = pos & 0xffffffff;
 	id->vpi_depth  = (pos >> PGC_DEPTH_SHIFT) & 0xf;
-	id->vpi_bucket = ((unsigned long long)pos >> PGC_OBJ_SHIFT);
+	id->vpi_bucket = (unsigned long long)pos >> PGC_OBJ_SHIFT;
 static loff_t vvp_pgcache_id_pack(struct vvp_pgcache_id *id)
