staging: make i2c device id constant
Author: Németh Márton <nm127@freemail.hu>
The id_table field of the struct i2c_driver is constant in
so it is worth to make the initialization data also constant.
The semantic match that finds this kind of pattern is as follows:
(http://coccinelle.lip6.fr/)
@r@
disable decl_init,const_decl_init;
identifier I1, I2, x;
	struct I1 {
	  const struct I2 *x;
@s@
identifier r.I1, y;
identifier r.x, E;
	struct I1 y = {
	  .x = E,
@c@
identifier r.I2;
identifier s.E;
	const struct I2 E[] = ... ;
@depends on !c@
identifier r.I2;
identifier s.E;
+	const
	struct I2 E[] = ...;
Signed-off-by: Németh Márton
Cc: Julia Lawall
Cc: cocci@diku.dk
 drivers/staging/go7007/s2250-board.c    | 2 +-
 drivers/staging/go7007/wis-ov7640.c     | 2 +-
 drivers/staging/go7007/wis-saa7113.c    | 2 +-
 drivers/staging/go7007/wis-saa7115.c    | 2 +-
 drivers/staging/go7007/wis-sony-tuner.c | 2 +-
 drivers/staging/go7007/wis-tw2804.c     | 2 +-
 drivers/staging/go7007/wis-tw9903.c     | 2 +-
 drivers/staging/go7007/wis-uda1342.c    | 2 +-
 8 files changed, 8 insertions(+), 8 deletions(-)
diff --git a/drivers/staging/go7007/s2250-board.c b/drivers/staging/go7007/s2250-board.c
index 8cf7f27..977df13 100644
--- a/drivers/staging/go7007/s2250-board.c
+++ b/drivers/staging/go7007/s2250-board.c
@@ -667,7 +667,7 @@ static int s2250_remove(struct i2c_client *client)
 	return 0;
-static struct i2c_device_id s2250_id[] = {
+static const struct i2c_device_id s2250_id[] = {
 	{ "s2250", 0 },
diff --git a/drivers/staging/go7007/wis-ov7640.c b/drivers/staging/go7007/wis-ov7640.c
index 04d6d3a..4f0cbdd 100644
--- a/drivers/staging/go7007/wis-ov7640.c
+++ b/drivers/staging/go7007/wis-ov7640.c
@@ -77,7 +77,7 @@ static int wis_ov7640_remove(struct i2c_client *client)
 	return 0;
-static struct i2c_device_id wis_ov7640_id[] = {
+static const struct i2c_device_id wis_ov7640_id[] = {
 	{ "wis_ov7640", 0 },
diff --git a/drivers/staging/go7007/wis-saa7113.c b/drivers/staging/go7007/wis-saa7113.c
index 9ab893b..d196e16f 100644
--- a/drivers/staging/go7007/wis-saa7113.c
+++ b/drivers/staging/go7007/wis-saa7113.c
@@ -304,7 +304,7 @@ static int wis_saa7113_remove(struct i2c_client *client)
 	return 0;
-static struct i2c_device_id wis_saa7113_id[] = {
+static const struct i2c_device_id wis_saa7113_id[] = {
 	{ "wis_saa7113", 0 },
diff --git a/drivers/staging/go7007/wis-saa7115.c b/drivers/staging/go7007/wis-saa7115.c
index 8687ad2..0f2b4a0 100644
--- a/drivers/staging/go7007/wis-saa7115.c
+++ b/drivers/staging/go7007/wis-saa7115.c
@@ -437,7 +437,7 @@ static int wis_saa7115_remove(struct i2c_client *client)
 	return 0;
-static struct i2c_device_id wis_saa7115_id[] = {
+static const struct i2c_device_id wis_saa7115_id[] = {
 	{ "wis_saa7115", 0 },
diff --git a/drivers/staging/go7007/wis-sony-tuner.c b/drivers/staging/go7007/wis-sony-tuner.c
index 086896c..c723e4a 100644
--- a/drivers/staging/go7007/wis-sony-tuner.c
+++ b/drivers/staging/go7007/wis-sony-tuner.c
@@ -688,7 +688,7 @@ static int wis_sony_tuner_remove(struct i2c_client *client)
 	return 0;
-static struct i2c_device_id wis_sony_tuner_id[] = {
+static const struct i2c_device_id wis_sony_tuner_id[] = {
 	{ "wis_sony_tuner", 0 },
diff --git a/drivers/staging/go7007/wis-tw2804.c b/drivers/staging/go7007/wis-tw2804.c
index e15794a..1983839 100644
--- a/drivers/staging/go7007/wis-tw2804.c
+++ b/drivers/staging/go7007/wis-tw2804.c
@@ -327,7 +327,7 @@ static int wis_tw2804_remove(struct i2c_client *client)
 	return 0;
-static struct i2c_device_id wis_tw2804_id[] = {
+static const struct i2c_device_id wis_tw2804_id[] = {
 	{ "wis_tw2804", 0 },
diff --git a/drivers/staging/go7007/wis-tw9903.c b/drivers/staging/go7007/wis-tw9903.c
index 506dca6..f97e2be 100644
--- a/drivers/staging/go7007/wis-tw9903.c
+++ b/drivers/staging/go7007/wis-tw9903.c
@@ -309,7 +309,7 @@ static int wis_tw9903_remove(struct i2c_client *client)
 	return 0;
-static struct i2c_device_id wis_tw9903_id[] = {
+static const struct i2c_device_id wis_tw9903_id[] = {
 	{ "wis_tw9903", 0 },
diff --git a/drivers/staging/go7007/wis-uda1342.c b/drivers/staging/go7007/wis-uda1342.c
index 739c7ae..5c4eb49 100644
--- a/drivers/staging/go7007/wis-uda1342.c
+++ b/drivers/staging/go7007/wis-uda1342.c
@@ -82,7 +82,7 @@ static int wis_uda1342_remove(struct i2c_client *client)
 	return 0;
-static struct i2c_device_id wis_uda1342_id[] = {
+static const struct i2c_device_id wis_uda1342_id[] = {
 	{ "wis_uda1342", 0 },
BtrLinux
Privacy Overview
