drivers/staging/asus_oled/asus_oled.c | 2 +-
drivers/staging/comedi/drivers/dt9812.c | 2 +-
drivers/staging/comedi/drivers/usbdux.c | 2 +-
drivers/staging/comedi/drivers/usbduxfast.c | 2 +-
drivers/staging/comedi/drivers/vmk80xx.c | 2 +-
drivers/staging/frontier/alphatrack.c | 2 +-
drivers/staging/frontier/tranzport.c | 2 +-
drivers/staging/go7007/go7007-usb.c | 2 +-
drivers/staging/go7007/s2250-loader.c | 2 +-
drivers/staging/line6/driver.c | 2 +-
drivers/staging/otus/zdusb.c | 2 +-
drivers/staging/quatech_usb2/quatech_usb2.c | 2 +-
drivers/staging/rtl8192su/r8192U_core.c | 2 +-
drivers/staging/rtl8192u/r8192U_core.c | 2 +-
drivers/staging/serqt_usb2/serqt_usb2.c | 2 +-
drivers/staging/winbond/wbusb.c | 2 +-
16 files changed, 16 insertions(+), 16 deletions(-)
diff --git a/drivers/staging/asus_oled/asus_oled.c b/drivers/staging/asus_oled/asus_oled.c
index c597fb2..cadb6f7 100644
--- a/drivers/staging/asus_oled/asus_oled.c
+++ b/drivers/staging/asus_oled/asus_oled.c
@@ -87,7 +87,7 @@ struct oled_dev_desc_str {
/* table of devices that work with this driver */
-static struct usb_device_id id_table[] = {
+static const struct usb_device_id id_table[] = {
/* Asus G1/G2 (and variants)*/
{ USB_DEVICE(USB_VENDOR_ID_ASUS, USB_DEVICE_ID_ASUS_LCM) },
/* Asus G50V (and possibly others - G70? G71?)*/
diff --git a/drivers/staging/comedi/drivers/dt9812.c b/drivers/staging/comedi/drivers/dt9812.c
index 312f4f2..96caae3 100644
--- a/drivers/staging/comedi/drivers/dt9812.c
+++ b/drivers/staging/comedi/drivers/dt9812.c
@@ -264,7 +264,7 @@ struct dt9812_usb_cmd {
static DECLARE_MUTEX(dt9812_mutex);
-static struct usb_device_id dt9812_table[] = {
+static const struct usb_device_id dt9812_table[] = {
{USB_DEVICE(0x0867, 0x9812)},
{} /* Terminating entry */
diff --git a/drivers/staging/comedi/drivers/usbdux.c b/drivers/staging/comedi/drivers/usbdux.c
index 9a1b559..0c854a6 100644
--- a/drivers/staging/comedi/drivers/usbdux.c
+++ b/drivers/staging/comedi/drivers/usbdux.c
@@ -2833,7 +2833,7 @@ static struct comedi_driver driver_usbdux = {
/* Table with the USB-devices: just now only testing IDs */
-static struct usb_device_id usbduxsub_table[] = {
+static const struct usb_device_id usbduxsub_table[] = {
{USB_DEVICE(0x13d8, 0x0001)},
{USB_DEVICE(0x13d8, 0x0002)},
diff --git a/drivers/staging/comedi/drivers/usbduxfast.c b/drivers/staging/comedi/drivers/usbduxfast.c
index 2e675cc..4ff4886 100644
--- a/drivers/staging/comedi/drivers/usbduxfast.c
+++ b/drivers/staging/comedi/drivers/usbduxfast.c
@@ -1769,7 +1769,7 @@ static struct comedi_driver driver_usbduxfast = {
-static struct usb_device_id usbduxfastsub_table[] = {
+static const struct usb_device_id usbduxfastsub_table[] = {
/* { USB_DEVICE(0x4b4, 0x8613) }, testing */
{USB_DEVICE(0x13d8, 0x0010)}, /* real ID */
{USB_DEVICE(0x13d8, 0x0011)}, /* real ID */
diff --git a/drivers/staging/comedi/drivers/vmk80xx.c b/drivers/staging/comedi/drivers/vmk80xx.c
index c34a0b9..6479c38 100644
--- a/drivers/staging/comedi/drivers/vmk80xx.c
+++ b/drivers/staging/comedi/drivers/vmk80xx.c
@@ -75,7 +75,7 @@ enum {
DEVICE_VMK8061
-static struct usb_device_id vmk80xx_id_table[] = {
+static const struct usb_device_id vmk80xx_id_table[] = {
{USB_DEVICE(0x10cf, 0x5500), .driver_info = DEVICE_VMK8055},
{USB_DEVICE(0x10cf, 0x5501), .driver_info = DEVICE_VMK8055},
{USB_DEVICE(0x10cf, 0x5502), .driver_info = DEVICE_VMK8055},
diff --git a/drivers/staging/frontier/alphatrack.c b/drivers/staging/frontier/alphatrack.c
index 15aed87..a50a215 100644
--- a/drivers/staging/frontier/alphatrack.c
+++ b/drivers/staging/frontier/alphatrack.c
@@ -58,7 +58,7 @@
#endif
-static struct usb_device_id usb_alphatrack_table[] = {
+static const struct usb_device_id usb_alphatrack_table[] = {
{USB_DEVICE(VENDOR_ID, PRODUCT_ID)},
diff --git a/drivers/staging/frontier/tranzport.c b/drivers/staging/frontier/tranzport.c
index ef8fcc8..2f03f43 100644
--- a/drivers/staging/frontier/tranzport.c
+++ b/drivers/staging/frontier/tranzport.c
@@ -55,7 +55,7 @@
#endif
-static struct usb_device_id usb_tranzport_table[] = {
+static const struct usb_device_id usb_tranzport_table[] = {
diff --git a/drivers/staging/go7007/go7007-usb.c b/drivers/staging/go7007/go7007-usb.c
index 1e89dc0..baace83 100644
--- a/drivers/staging/go7007/go7007-usb.c
+++ b/drivers/staging/go7007/go7007-usb.c
@@ -444,7 +444,7 @@ static struct go7007_usb_board board_sensoray_2250 = {
-static struct usb_device_id go7007_usb_id_table[] = {
+static const struct usb_device_id go7007_usb_id_table[] = {
.match_flags = USB_DEVICE_ID_MATCH_DEVICE_AND_VERSION |
USB_DEVICE_ID_MATCH_INT_INFO,
diff --git a/drivers/staging/go7007/s2250-loader.c b/drivers/staging/go7007/s2250-loader.c
index c152ab9..ef833e0 100644
--- a/drivers/staging/go7007/s2250-loader.c
+++ b/drivers/staging/go7007/s2250-loader.c
@@ -148,7 +148,7 @@ static void s2250loader_disconnect(struct usb_interface *interface)
unlock_kernel();
-static struct usb_device_id s2250loader_ids[] = {
+static const struct usb_device_id s2250loader_ids[] = {
{USB_DEVICE(0x1943, 0xa250)},
diff --git a/drivers/staging/line6/driver.c b/drivers/staging/line6/driver.c
index e4078a9..0392a4b 100644
--- a/drivers/staging/line6/driver.c
+++ b/drivers/staging/line6/driver.c
@@ -33,7 +33,7 @@
-static struct usb_device_id line6_id_table[] = {
+static const struct usb_device_id line6_id_table[] = {
{ USB_DEVICE(LINE6_VENDOR_ID, LINE6_DEVID_BASSPODXT) },
{ USB_DEVICE(LINE6_VENDOR_ID, LINE6_DEVID_BASSPODXTLIVE) },
{ USB_DEVICE(LINE6_VENDOR_ID, LINE6_DEVID_BASSPODXTPRO) },
diff --git a/drivers/staging/otus/zdusb.c b/drivers/staging/otus/zdusb.c
index 2a6d937..4cd9b7f 100644
--- a/drivers/staging/otus/zdusb.c
+++ b/drivers/staging/otus/zdusb.c
@@ -45,7 +45,7 @@ MODULE_LICENSE("Dual BSD/GPL");
static const char driver_name[] = "Otus";
-static struct usb_device_id zd1221_ids [] = {
+static const struct usb_device_id zd1221_ids[] = {
{ USB_DEVICE(VENDOR_ATHR, PRODUCT_AR9170) },
{ USB_DEVICE(VENDOR_DLINK, PRODUCT_DWA160A) },
{ USB_DEVICE(VENDOR_NETGEAR, PRODUCT_WNDA3100) },
diff --git a/drivers/staging/quatech_usb2/quatech_usb2.c b/drivers/staging/quatech_usb2/quatech_usb2.c
index f7726f1..1561f74 100644
--- a/drivers/staging/quatech_usb2/quatech_usb2.c
+++ b/drivers/staging/quatech_usb2/quatech_usb2.c
@@ -116,7 +116,7 @@ static int debug;
#define FOURTHCHAR ((unsigned char *)(urb->transfer_buffer))[i + 3]
#define FIFTHCHAR ((unsigned char *)(urb->transfer_buffer))[i + 4]
-static struct usb_device_id quausb2_id_table[] = {
+static const struct usb_device_id quausb2_id_table[] = {
{USB_DEVICE(USB_VENDOR_ID_QUATECH, QUATECH_SSU2_100)},
{USB_DEVICE(USB_VENDOR_ID_QUATECH, QUATECH_DSU2_100)},
{USB_DEVICE(USB_VENDOR_ID_QUATECH, QUATECH_DSU2_400)},
diff --git a/drivers/staging/rtl8192su/r8192U_core.c b/drivers/staging/rtl8192su/r8192U_core.c
index f15be1e..23d1d35 100644
--- a/drivers/staging/rtl8192su/r8192U_core.c
+++ b/drivers/staging/rtl8192su/r8192U_core.c
@@ -110,7 +110,7 @@ u32 rt_global_debug_component = \
#define TOTAL_CAM_ENTRY 32
#define CAM_CONTENT_COUNT 8
-static struct usb_device_id rtl8192_usb_id_tbl[] = {
+static const struct usb_device_id rtl8192_usb_id_tbl[] = {
/* Realtek */
{USB_DEVICE(0x0bda, 0x8192)},
{USB_DEVICE(0x0bda, 0x8709)},
diff --git a/drivers/staging/rtl8192u/r8192U_core.c b/drivers/staging/rtl8192u/r8192U_core.c
index 7cf7ea7..f1e085b 100644
--- a/drivers/staging/rtl8192u/r8192U_core.c
+++ b/drivers/staging/rtl8192u/r8192U_core.c
@@ -104,7 +104,7 @@ u32 rt_global_debug_component = \
/* Realtek */
diff --git a/drivers/staging/serqt_usb2/serqt_usb2.c b/drivers/staging/serqt_usb2/serqt_usb2.c
index 060e9de..375a505 100644
--- a/drivers/staging/serqt_usb2/serqt_usb2.c
+++ b/drivers/staging/serqt_usb2/serqt_usb2.c
@@ -126,7 +126,7 @@ static int debug;
#define MODEM_CTRL 0x40
#define RS232_MODE 0x00
-static struct usb_device_id serqt_id_table[] = {
+static const struct usb_device_id serqt_id_table[] = {
{USB_DEVICE(USB_VENDOR_ID_QUATECH, QUATECH_SSU100)},
{USB_DEVICE(USB_VENDOR_ID_QUATECH, QUATECH_SSU200)},
{USB_DEVICE(USB_VENDOR_ID_QUATECH, QUATECH_DSU100)},
diff --git a/drivers/staging/winbond/wbusb.c b/drivers/staging/winbond/wbusb.c
index 1c58763..ecf418d 100644
--- a/drivers/staging/winbond/wbusb.c
+++ b/drivers/staging/winbond/wbusb.c
@@ -23,7 +23,7 @@ MODULE_DESCRIPTION("IS89C35 802.11bg WLAN USB Driver");
MODULE_LICENSE("GPL");
MODULE_VERSION("0.1");
-static struct usb_device_id wb35_table[] __devinitdata = {
+static const struct usb_device_id wb35_table[] __devinitconst = {
{ USB_DEVICE(0x0416, 0x0035) },
{ USB_DEVICE(0x18E8, 0x6201) },
{ USB_DEVICE(0x18E8, 0x6206) }, |
