staging: lustre: remove extra parentheses around left bit shift operations
Author: Aya Mahfouz <mahfouz.saif.elyazal@gmail.com>
Removes extra parentheses around bitwise left shift operations.
The cases handled here are when resultant values are assigned to
variables. The issue was detected and resolved using the following
coccinelle script:
expression e, e1;
constant c;
e =
-(e1
+e1
-c);
+c;
identifier i;
constant c;
type t;
expression e;
t i =
-(e
+e
-c);
+c;
expression e, e1;
identifier f;
constant c;
e1 = f(...,
-(e
+e
-c)
+c
Signed-off-by: Aya Mahfouz
 drivers/staging/lustre/lnet/klnds/socklnd/socklnd_modparams.c | 6 +++---
 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/drivers/staging/lustre/lnet/klnds/socklnd/socklnd_modparams.c b/drivers/staging/lustre/lnet/klnds/socklnd/socklnd_modparams.c
index 66d78c9..86b88db 100644
--- a/drivers/staging/lustre/lnet/klnds/socklnd/socklnd_modparams.c
+++ b/drivers/staging/lustre/lnet/klnds/socklnd/socklnd_modparams.c
@@ -72,7 +72,7 @@ static int typed_conns = 1;
 module_param(typed_conns, int, 0444);
 MODULE_PARM_DESC(typed_conns, "use different sockets for bulk");
-static int min_bulk = (1<<10);
+static int min_bulk = 1<<10;
 module_param(min_bulk, int, 0644);
 MODULE_PARM_DESC(min_bulk, "smallest 'large' message");
@@ -122,7 +122,7 @@ static int nonblk_zcack = 1;
 module_param(nonblk_zcack, int, 0644);
 MODULE_PARM_DESC(nonblk_zcack, "always send ZC-ACK on non-blocking connection");
-static unsigned int zc_min_payload = (16 << 10);
+static unsigned int zc_min_payload = 16 << 10;
 module_param(zc_min_payload, int, 0644);
 MODULE_PARM_DESC(zc_min_payload, "minimum payload size to zero copy");
@@ -182,7 +182,7 @@ int ksocknal_tunables_init(void)
 #endif
 	if (*ksocknal_tunables.ksnd_zc_min_payload < (2 << 10))
-		*ksocknal_tunables.ksnd_zc_min_payload = (2 << 10);
+		*ksocknal_tunables.ksnd_zc_min_payload = 2 << 10;
 	return 0;
BtrLinux
Privacy Overview
