staging: ozwpan: remove extra parentheses around left bit shift operations
Author: Aya Mahfouz <mahfouz.saif.elyazal@gmail.com>
Removes extra parentheses around bitwise left shift operations.
The case handled is when resultant value is assigned to a variable.
The issue was detected and resolved using the following
coccinelle script:
expression e, e1;
constant c;
e =
-(e1
+e1
-c);
+c;
identifier i;
constant c;
type t;
expression e;
t i =
-(e
+e
-c);
+c;
Signed-off-by: Aya Mahfouz
 drivers/staging/ozwpan/ozproto.c | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/staging/ozwpan/ozproto.c b/drivers/staging/ozwpan/ozproto.c
index 3d3a3a8..1ba24a2 100644
--- a/drivers/staging/ozwpan/ozproto.c
+++ b/drivers/staging/ozwpan/ozproto.c
@@ -98,7 +98,7 @@ static void oz_send_conn_rsp(struct oz_pd *pd, u8 status)
 		kfree_skb(skb);
 		return;
-	oz_hdr->control = (OZ_PROTOCOL_VERSION<<OZ_VERSION_SHIFT);
+	oz_hdr->control = OZ_PROTOCOL_VERSION<<OZ_VERSION_SHIFT;
 	oz_hdr->last_pkt_num = 0;
 	put_unaligned(0, &oz_hdr->pkt_num);
 	elt->type = OZ_ELT_CONNECT_RSP;
