Staging: lustre: ptlrpc: Remove braces for single statement blocks
Author: Shraddha Barke <shraddha.6596@gmail.com>
The linux kernel coding style discourages use of braces for single
statement blocks. This patch removes the unnecessary braces.
The warning was detected using checkpatch.pl. Coccinelle was used to
make the change.
Signed-off-by: Shraddha Barke
 drivers/staging/lustre/lustre/ptlrpc/client.c | 5 ++---
 1 file changed, 2 insertions(+), 3 deletions(-)
diff --git a/drivers/staging/lustre/lustre/ptlrpc/client.c b/drivers/staging/lustre/lustre/ptlrpc/client.c
index 865c8a2..1800db1 100644
--- a/drivers/staging/lustre/lustre/ptlrpc/client.c
+++ b/drivers/staging/lustre/lustre/ptlrpc/client.c
@@ -1164,12 +1164,11 @@ static int ptlrpc_check_status(struct ptlrpc_request *req)
 		return err < 0 ? err : -EINVAL;
-	if (err < 0) {
+	if (err < 0)
 		DEBUG_REQ(D_INFO, req, "status is %d", err);
-	} else if (err > 0) {
+	else if (err > 0)
 		/* XXX: translate this error from net to host */
 	return err;
BtrLinux
Privacy Overview
