Staging: rtl8723au: hal: Remove braces for single statement blocks
Author: Shraddha Barke <shraddha.6596@gmail.com>
The linux kernel coding style discourages use of braces for single
statement blocks. This patch removes the unnecessary braces.
The error was detected using checkpatch.pl. Coccinelle was used
to make the change.
Signed-off-by: Shraddha Barke
drivers/staging/rtl8723au/hal/usb_halinit.c | 5 ++---
1 file changed, 2 insertions(+), 3 deletions(-)
diff --git a/drivers/staging/rtl8723au/hal/usb_halinit.c b/drivers/staging/rtl8723au/hal/usb_halinit.c
index 68156a1..9926b07 100644
--- a/drivers/staging/rtl8723au/hal/usb_halinit.c
+++ b/drivers/staging/rtl8723au/hal/usb_halinit.c
@@ -834,12 +834,11 @@ static void phy_SsPwrSwitch92CU(struct rtw_adapter *Adapter,
rtl8723au_read32(Adapter, rOFDM0_TRxPathEnable);
Adapter->pwrctrlpriv.PS_BBRegBackup[PSBBREG_RF2] =
rtl8723au_read32(Adapter, rFPGA0_RFMOD);
- if (pHalData->rf_type == RF_2T2R) {
+ if (pHalData->rf_type == RF_2T2R)
PHY_SetBBReg(Adapter, rFPGA0_XAB_RFParameter,
0x380038, 0);
- } else if (pHalData->rf_type == RF_1T1R) {
+ else if (pHalData->rf_type == RF_1T1R)
PHY_SetBBReg(Adapter, rFPGA0_XAB_RFParameter, 0x38, 0);
PHY_SetBBReg(Adapter, rOFDM0_TRxPathEnable, 0xf0, 0);
PHY_SetBBReg(Adapter, rFPGA0_RFMOD, BIT(1), 1); |
0x380038, 0);
