staging: lustre: lnet: o2iblnd: Use list_for_each_entry_safe
Author: Bhaktipriya Shridhar <bhaktipriya96@gmail.com>
Doubly linked lists which are  iterated  using list_empty
and list_entry macros have been replaced with list_for_each_entry_safe
macro.
This makes the iteration simpler and more readable.
This patch replaces the while loop containing list_empty and list_entry
with list_for_each_entry_safe.
This was done with Coccinelle.
expression E1;
identifier I1, I2;
type T;
iterator name list_for_each_entry_safe;
T *I1;
+ T *tmp;
- while (list_empty(&E1) == 0)
+ list_for_each_entry_safe (I1, tmp, &E1, I2)
...when != T *I1;
- I1 = list_entry(E1.next, T, I2);
Signed-off-by: Bhaktipriya Shridhar
 drivers/staging/lustre/lnet/klnds/o2iblnd/o2iblnd_cb.c | 4 ++--
 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/staging/lustre/lnet/klnds/o2iblnd/o2iblnd_cb.c b/drivers/staging/lustre/lnet/klnds/o2iblnd/o2iblnd_cb.c
index 79051c0..2323e8d 100644
--- a/drivers/staging/lustre/lnet/klnds/o2iblnd/o2iblnd_cb.c
+++ b/drivers/staging/lustre/lnet/klnds/o2iblnd/o2iblnd_cb.c
@@ -3157,6 +3157,7 @@ kiblnd_check_conns(int idx)
 	struct list_head *ptmp;
 	kib_peer_t *peer;
 	kib_conn_t *conn;
+	kib_conn_t *temp;
 	kib_conn_t *tmp;
 	struct list_head *ctmp;
 	unsigned long flags;
@@ -3225,8 +3226,7 @@ kiblnd_check_conns(int idx)
 	 * NOOP, but there were no non-blocking tx descs
 	 * free to do it last time...
-	while (!list_empty(&checksends)) {
-		conn = list_entry(checksends.next, kib_conn_t, ibc_connd_list);
+	list_for_each_entry_safe(conn, temp, &checksends, ibc_connd_list) {
 		list_del(&conn->ibc_connd_list);
 		kiblnd_check_sends(conn);
 		kiblnd_conn_decref(conn);
BtrLinux
Privacy Overview
