staging: lustre: lnet: socklnd: Use list_for_each_entry_safe
Author: Bhaktipriya Shridhar <bhaktipriya96@gmail.com>
Doubly linked lists which are iterated using list_empty
and list_entry macros have been replaced with list_for_each_entry_safe
macro.
This makes the iteration simpler and more readable.
This patch replaces the while loop containing list_empty and list_entry
with list_for_each_entry_safe.
This was done with Coccinelle.
expression E1;
identifier I1, I2;
type T;
iterator name list_for_each_entry_safe;
T *I1;
+ T *tmp;
- while (list_empty(&E1) == 0)
+ list_for_each_entry_safe (I1, tmp, &E1, I2)
...when != T *I1;
- I1 = list_entry(E1.next, T, I2);
Signed-off-by: Bhaktipriya Shridhar
drivers/staging/lustre/lnet/klnds/socklnd/socklnd.c | 9 ++++-----
1 file changed, 4 insertions(+), 5 deletions(-)
diff --git a/drivers/staging/lustre/lnet/klnds/socklnd/socklnd.c b/drivers/staging/lustre/lnet/klnds/socklnd/socklnd.c
index a710541..cca7b2f 100644
--- a/drivers/staging/lustre/lnet/klnds/socklnd/socklnd.c
+++ b/drivers/staging/lustre/lnet/klnds/socklnd/socklnd.c
@@ -1556,6 +1556,7 @@ ksocknal_finalize_zcreq(ksock_conn_t *conn)
ksock_peer_t *peer = conn->ksnc_peer;
ksock_tx_t *tx;
+ ksock_tx_t *temp;
ksock_tx_t *tmp;
LIST_HEAD(zlist);
@@ -1581,9 +1582,7 @@ ksocknal_finalize_zcreq(ksock_conn_t *conn)
spin_unlock(&peer->ksnp_lock);
- while (!list_empty(&zlist)) {
- tx = list_entry(zlist.next, ksock_tx_t, tx_zc_list);
+ list_for_each_entry_safe(tx, temp, &zlist, tx_zc_list) {
list_del(&tx->tx_zc_list);
ksocknal_tx_decref(tx);
@@ -2286,13 +2285,13 @@ ksocknal_free_buffers(void)
if (!list_empty(&ksocknal_data.ksnd_idle_noop_txs)) {
struct list_head zlist;
ksock_tx_t *tx;
+ ksock_tx_t *temp;
list_add(&zlist, &ksocknal_data.ksnd_idle_noop_txs);
list_del_init(&ksocknal_data.ksnd_idle_noop_txs);
spin_unlock(&ksocknal_data.ksnd_tx_lock);
- tx = list_entry(zlist.next, ksock_tx_t, tx_list);
+ list_for_each_entry_safe(tx, temp, &zlist, tx_list) {
list_del(&tx->tx_list);
LIBCFS_FREE(tx, tx->tx_desc_size);
ksock_tx_t *tx;
+ ksock_tx_t *temp;
ksock_tx_t *tmp;
LIST_HEAD(zlist);
ksock_tx_t *tx;
+ ksock_tx_t *temp;
