staging: lustre: lnet: lnet: fix error return code
Author: Julia Lawall <Julia.Lawall@lip6.fr>
Return a negative error code on failure.
A simplified version of the semantic match that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
identifier ret; expression e1,e2;
if (\(ret < 0\|ret != 0\))
 { ... return ret; }
ret = 0
... when != ret = e1
    when != &ret
*if(...)
  ... when != ret = e2
      when forall
 return ret;
Signed-off-by: Julia Lawall
 drivers/staging/lustre/lnet/lnet/api-ni.c | 8 ++++++--
 1 file changed, 6 insertions(+), 2 deletions(-)
diff --git a/drivers/staging/lustre/lnet/lnet/api-ni.c b/drivers/staging/lustre/lnet/lnet/api-ni.c
index faceb95..4a14e51 100644
--- a/drivers/staging/lustre/lnet/lnet/api-ni.c
+++ b/drivers/staging/lustre/lnet/lnet/api-ni.c
@@ -650,15 +650,19 @@ lnet_prepare(lnet_pid_t requested_pid)
 	recs = lnet_res_containers_create(LNET_COOKIE_TYPE_ME, LNET_FL_MAX_MES,
 					  sizeof(lnet_me_t));
-	if (recs == NULL)
+	if (recs == NULL) {
+		rc = -ENOMEM;
 		goto failed;
 	the_lnet.ln_me_containers = recs;
 	recs = lnet_res_containers_create(LNET_COOKIE_TYPE_MD, LNET_FL_MAX_MDS,
 					  sizeof(lnet_libmd_t));
-	if (recs == NULL)
+		rc = -ENOMEM;
 		goto failed;
 	the_lnet.ln_md_containers = recs;
BtrLinux
Privacy Overview
