staging: lustre: lclient: Replace kmem_cache_alloc with kmem_cache_zalloc
Author: Amitoj Kaur Chawla <amitoj1606@gmail.com>
Use kmem_cache_zalloc instead of manually setting kmem_cache_alloc
with flag GFP_ZERO since kmem_alloc_zalloc sets allocated memory
to zero.
The Coccinelle semantic patch used to make this change is as
follows:
expression e,f;
- kmem_cache_alloc(e, f |__GFP_ZERO)
+ kmem_cache_zalloc(e, f)
Signed-off-by: Amitoj Kaur Chawla
 drivers/staging/lustre/lustre/lclient/lcommon_cl.c | 10 +++++-----
 1 file changed, 5 insertions(+), 5 deletions(-)
diff --git a/drivers/staging/lustre/lustre/lclient/lcommon_cl.c b/drivers/staging/lustre/lustre/lclient/lcommon_cl.c
index 30651f2..aced41a 100644
--- a/drivers/staging/lustre/lustre/lclient/lcommon_cl.c
+++ b/drivers/staging/lustre/lustre/lclient/lcommon_cl.c
@@ -116,7 +116,7 @@ void *ccc_key_init(const struct lu_context *ctx, struct lu_context_key *key)
 	struct ccc_thread_info *info;
-	info = kmem_cache_alloc(ccc_thread_kmem, GFP_NOFS | __GFP_ZERO);
+	info = kmem_cache_zalloc(ccc_thread_kmem, GFP_NOFS);
 	if (!info)
 		info = ERR_PTR(-ENOMEM);
 	return info;
@@ -135,7 +135,7 @@ void *ccc_session_key_init(const struct lu_context *ctx,
 	struct ccc_session *session;
-	session = kmem_cache_alloc(ccc_session_kmem, GFP_NOFS | __GFP_ZERO);
+	session = kmem_cache_zalloc(ccc_session_kmem, GFP_NOFS);
 	if (!session)
 		session = ERR_PTR(-ENOMEM);
 	return session;
@@ -251,7 +251,7 @@ int ccc_req_init(const struct lu_env *env, struct cl_device *dev,
 	struct ccc_req *vrq;
 	int result;
-	vrq = kmem_cache_alloc(ccc_req_kmem, GFP_NOFS | __GFP_ZERO);
+	vrq = kmem_cache_zalloc(ccc_req_kmem, GFP_NOFS);
 	if (vrq) {
 		cl_req_slice_add(req, &vrq->crq_cl, dev, &ccc_req_ops);
 		result = 0;
@@ -327,7 +327,7 @@ struct lu_object *ccc_object_alloc(const struct lu_env *env,
 	struct ccc_object *vob;
 	struct lu_object  *obj;
-	vob = kmem_cache_alloc(ccc_object_kmem, GFP_NOFS | __GFP_ZERO);
+	vob = kmem_cache_zalloc(ccc_object_kmem, GFP_NOFS);
 	if (vob) {
 		struct cl_object_header *hdr;
@@ -396,7 +396,7 @@ int ccc_lock_init(const struct lu_env *env,
 	CLOBINVRNT(env, obj, ccc_object_invariant(obj));
-	clk = kmem_cache_alloc(ccc_lock_kmem, GFP_NOFS | __GFP_ZERO);
+	clk = kmem_cache_zalloc(ccc_lock_kmem, GFP_NOFS);
 	if (clk) {
 		cl_lock_slice_add(lock, &clk->clk_cl, obj, lkops);
 		result = 0;
BtrLinux
Privacy Overview
