Staging: lustre: lov: Use list_for_each_entry instead of list_for_each
Author: Bhumika Goyal <bhumirks@gmail.com>
Use list_for_each_entry instead of list_for_each and list_entry as it
simplifies the code. Done using coccinelle:
type T,T2;
identifier I1,I2;
expression e1,e2;
iterator name list_for_each_entry;
iterator name list_for_each;
- T *I1;
- list_for_each(I1,e1)
+ list_for_each_entry(I2,e1,e2)
...when!=T *I1;
- I2=list_entry(I1,T2,e2);
...when!=I2;
type T,T2,T3;
identifier I1,I2,I3;
expression e1,e2;
- T *I1;
+ T3 *I3;
+ list_for_each_entry(I3,e1,e2)
...when!=T *I1;
- T3 *I3=list_entry(I1,T2,e2);
...when!=I3;
Signed-off-by: Bhumika Goyal
 drivers/staging/lustre/lustre/lov/lov_obd.c     | 19 ++++---------------
 drivers/staging/lustre/lustre/lov/lov_request.c |  5 +----
 2 files changed, 5 insertions(+), 19 deletions(-)
diff --git a/drivers/staging/lustre/lustre/lov/lov_obd.c b/drivers/staging/lustre/lustre/lov/lov_obd.c
index 846683b..7ba670a 100644
--- a/drivers/staging/lustre/lustre/lov/lov_obd.c
+++ b/drivers/staging/lustre/lustre/lov/lov_obd.c
@@ -1073,7 +1073,6 @@ static int lov_destroy(const struct lu_env *env, struct obd_export *exp,
 	struct lov_request_set *set;
 	struct obd_info oinfo;
 	struct lov_request *req;
-	struct list_head *pos;
 	struct lov_obd *lov;
 	int rc = 0, err = 0;
@@ -1093,9 +1092,7 @@ static int lov_destroy(const struct lu_env *env, struct obd_export *exp,
 	if (rc)
 		goto out;
-	list_for_each(pos, &set->set_list) {
-		req = list_entry(pos, struct lov_request, rq_link);
+	list_for_each_entry(req, &set->set_list, rq_link) {
 		if (oa->o_valid & OBD_MD_FLCOOKIE)
 			oti->oti_logcookies = set->set_cookies + req->rq_stripe;
@@ -1140,7 +1137,6 @@ static int lov_getattr_async(struct obd_export *exp, struct obd_info *oinfo,
 	struct lov_request_set *lovset;
 	int rc = 0, err;
@@ -1160,9 +1156,7 @@ static int lov_getattr_async(struct obd_export *exp, struct obd_info *oinfo,
 	       POSTID(&oinfo->oi_md->lsm_oi), oinfo->oi_md->lsm_stripe_count,
 	       oinfo->oi_md->lsm_stripe_size);
-	list_for_each(pos, &lovset->set_list) {
+	list_for_each_entry(req, &lovset->set_list, rq_link) {
 		CDEBUG(D_INFO, "objid " DOSTID "[%d] has subobj " DOSTID " at idx%u\n",
 		       POSTID(&oinfo->oi_oa->o_oi), req->rq_stripe,
 		       POSTID(&req->rq_oi.oi_oa->o_oi), req->rq_idx);
@@ -1214,7 +1208,6 @@ static int lov_setattr_async(struct obd_export *exp, struct obd_info *oinfo,
 	int rc = 0;
@@ -1238,9 +1231,7 @@ static int lov_setattr_async(struct obd_export *exp, struct obd_info *oinfo,
 		if (oinfo->oi_oa->o_valid & OBD_MD_FLCOOKIE)
@@ -1335,7 +1326,6 @@ static int lov_statfs_async(struct obd_export *exp, struct obd_info *oinfo,
 	struct obd_device      *obd = class_exp2obd(exp);
 	int rc = 0;
@@ -1346,8 +1336,7 @@ static int lov_statfs_async(struct obd_export *exp, struct obd_info *oinfo,
 	if (rc)
 		return rc;
 		rc = obd_statfs_async(lov->lov_tgts[req->rq_idx]->ltd_exp,
 				      &req->rq_oi, max_age, rqset);
 		if (rc)
diff --git a/drivers/staging/lustre/lustre/lov/lov_request.c b/drivers/staging/lustre/lustre/lov/lov_request.c
index 5408eef..42660f2 100644
--- a/drivers/staging/lustre/lustre/lov/lov_request.c
+++ b/drivers/staging/lustre/lustre/lov/lov_request.c
@@ -190,7 +190,6 @@ out:
 static int common_attr_done(struct lov_request_set *set)
 	struct obdo *tmp_oa;
 	int rc = 0, attrset = 0;
@@ -207,9 +206,7 @@ static int common_attr_done(struct lov_request_set *set)
 		goto out;
 		if (!req->rq_complete || req->rq_rc)
 			continue;
 		if (req->rq_oi.oi_oa->o_valid == 0)   /* inactive stripe */
