staging: lustre: fid,fld: expand the GOTO macro
Author: Julia Lawall <Julia.Lawall@lip6.fr>
The semantic patch that makes this change is as follows:
(http://coccinelle.lip6.fr/)
identifier lbl;
identifier rc;
constant c;
- GOTO(lbl,\(rc\|c\));
+ goto lbl;
identifier lbl;
expression rc;
- GOTO(lbl,rc);
+ rc;
+ goto lbl;
Signed-off-by: Julia Lawall
 drivers/staging/lustre/lustre/fid/fid_request.c | 18 +++++++++++-------
 drivers/staging/lustre/lustre/fld/fld_request.c | 14 ++++++++------
 2 files changed, 19 insertions(+), 13 deletions(-)
diff --git a/drivers/staging/lustre/lustre/fid/fid_request.c b/drivers/staging/lustre/lustre/fid/fid_request.c
index 46c11ca..64b1d80 100644
--- a/drivers/staging/lustre/lustre/fid/fid_request.c
+++ b/drivers/staging/lustre/lustre/fid/fid_request.c
@@ -113,7 +113,7 @@ static int seq_client_rpc(struct lu_client_seq *seq,
 	if (seq->lcs_type == LUSTRE_SEQ_METADATA)
 		mdc_put_rpc_lock(exp->exp_obd->u.cli.cl_rpc_lock, NULL);
 	if (rc)
-		GOTO(out_req, rc);
+		goto out_req;
 	out = req_capsule_server_get(&req->rq_pill, &RMF_SEQ_RANGE);
 	*output = *out;
@@ -121,13 +121,15 @@ static int seq_client_rpc(struct lu_client_seq *seq,
 	if (!range_is_sane(output)) {
 		CERROR("%s: Invalid range received from server: "
 		       DRANGE"\n", seq->lcs_name, PRANGE(output));
-		GOTO(out_req, rc = -EINVAL);
+		rc = -EINVAL;
+		goto out_req;
 	if (range_is_exhausted(output)) {
 		CERROR("%s: Range received from server is exhausted: "
 		       DRANGE"]\n", seq->lcs_name, PRANGE(output));
+		rc = -EINVAL;
+		goto out_req;
 	CDEBUG_LIMIT(debug_mask, "%s: Allocated %s-sequence "DRANGE"]\n",
@@ -430,7 +432,7 @@ static int seq_client_proc_init(struct lu_client_seq *seq)
 	if (rc) {
 		CERROR("%s: Can't init sequence manager proc, rc %d\n",
 		       seq->lcs_name, rc);
-		GOTO(out_cleanup, rc);
+		goto out_cleanup;
 	return 0;
@@ -508,8 +510,10 @@ int client_fid_init(struct obd_device *obd,
 		return -ENOMEM;
 	OBD_ALLOC(prefix, MAX_OBD_NAME + 5);
-	if (prefix == NULL)
-		GOTO(out_free_seq, rc = -ENOMEM);
+	if (prefix == NULL) {
+		rc = -ENOMEM;
+		goto out_free_seq;
 	snprintf(prefix, MAX_OBD_NAME + 5, "cli-%s", obd->obd_name);
@@ -517,7 +521,7 @@ int client_fid_init(struct obd_device *obd,
 	rc = seq_client_init(cli->cl_seq, exp, type, prefix, NULL);
 	OBD_FREE(prefix, MAX_OBD_NAME + 5);
 	if (rc)
-		GOTO(out_free_seq, rc);
 	return rc;
 out_free_seq:
diff --git a/drivers/staging/lustre/lustre/fld/fld_request.c b/drivers/staging/lustre/lustre/fld/fld_request.c
index 4539a02..f63c669 100644
--- a/drivers/staging/lustre/lustre/fld/fld_request.c
+++ b/drivers/staging/lustre/lustre/fld/fld_request.c
@@ -293,7 +293,7 @@ static int fld_client_proc_init(struct lu_client_fld *fld)
 	if (rc) {
 		CERROR("%s: Can't init FLD proc, rc %d\n",
 		       fld->lcf_name, rc);
+		goto out_cleanup;
 	return 0;
@@ -363,12 +363,12 @@ int fld_client_init(struct lu_client_fld *fld,
 	if (IS_ERR(fld->lcf_cache)) {
 		rc = PTR_ERR(fld->lcf_cache);
 		fld->lcf_cache = NULL;
-		GOTO(out, rc);
+		goto out;
 	rc = fld_client_proc_init(fld);
 	if (rc)
-		GOTO(out, rc);
+		goto out;
 out:
 	if (rc)
 		fld_client_fini(fld);
@@ -441,11 +441,13 @@ int fld_client_rpc(struct obd_export *exp,
 	if (fld_op != FLD_LOOKUP)
 	if (rc)
+		goto out_req;
 	prange = req_capsule_server_get(&req->rq_pill, &RMF_FLD_MDFLD);
-	if (prange == NULL)
-		GOTO(out_req, rc = -EFAULT);
+	if (prange == NULL) {
+		rc = -EFAULT;
+		goto out_req;
 	*range = *prange;
 out_req:
 	ptlrpc_req_finished(req);
BtrLinux
Privacy Overview
