drivers/staging/lustre/lustre/ldlm/ldlm_lock.c | 4 ++--
drivers/staging/lustre/lustre/llite/file.c | 4 ++--
drivers/staging/lustre/lustre/llite/llite_lib.c | 2 +-
drivers/staging/lustre/lustre/llite/lloop.c | 2 +-
drivers/staging/lustre/lustre/obdclass/class_obd.c | 2 +-
drivers/staging/lustre/lustre/obdclass/lprocfs_status.c | 2 +-
drivers/staging/lustre/lustre/obdclass/obd_config.c | 2 +-
drivers/staging/lustre/lustre/osc/osc_quota.c | 2 +-
drivers/staging/lustre/lustre/ptlrpc/connection.c | 2 +-
9 files changed, 11 insertions(+), 11 deletions(-)
diff --git a/drivers/staging/lustre/lustre/ldlm/ldlm_lock.c b/drivers/staging/lustre/lustre/ldlm/ldlm_lock.c
index 46b8b8c..7fa5d43 100644
--- a/drivers/staging/lustre/lustre/ldlm/ldlm_lock.c
+++ b/drivers/staging/lustre/lustre/ldlm/ldlm_lock.c
@@ -1747,7 +1747,7 @@ ldlm_work_revoke_ast_lock(struct ptlrpc_request_set *rqset, void *opaq)
desc.l_req_mode = LCK_EX;
desc.l_granted_mode = 0;
- rc = lock->l_blocking_ast(lock, &desc, (void*)arg, LDLM_CB_BLOCKING);
+ rc = lock->l_blocking_ast(lock, &desc, (void *)arg, LDLM_CB_BLOCKING);
LDLM_LOCK_RELEASE(lock);
return rc;
@@ -1776,7 +1776,7 @@ int ldlm_work_gl_ast_lock(struct ptlrpc_request_set *rqset, void *opaq)
arg->gl_desc = gl_work->gl_desc;
/* invoke the actual glimpse callback */
- if (lock->l_glimpse_ast(lock, (void*)arg) == 0)
+ if (lock->l_glimpse_ast(lock, (void *)arg) == 0)
rc = 1;
diff --git a/drivers/staging/lustre/lustre/llite/file.c b/drivers/staging/lustre/lustre/llite/file.c
index fb3320d..10a1475 100644
--- a/drivers/staging/lustre/lustre/llite/file.c
+++ b/drivers/staging/lustre/lustre/llite/file.c
@@ -1494,7 +1494,7 @@ static int ll_lov_setea(struct inode *inode, struct file *file,
if (lump == NULL)
return -ENOMEM;
- if (copy_from_user(lump, (struct lov_user_md *)arg, lum_size)) {
+ if (copy_from_user(lump, (struct lov_user_md *)arg, lum_size)) {
OBD_FREE_LARGE(lump, lum_size);
return -EFAULT;
@@ -2328,7 +2328,7 @@ ll_file_ioctl(struct file *file, unsigned int cmd, unsigned long arg)
if (mdtidx < 0)
return mdtidx;
- if (put_user((int)mdtidx, (int*)arg))
+ if (put_user((int)mdtidx, (int *)arg))
return -EFAULT;
return 0;
diff --git a/drivers/staging/lustre/lustre/llite/llite_lib.c b/drivers/staging/lustre/lustre/llite/llite_lib.c
index 454f048..097ee1b 100644
--- a/drivers/staging/lustre/lustre/llite/llite_lib.c
+++ b/drivers/staging/lustre/lustre/llite/llite_lib.c
@@ -2175,7 +2175,7 @@ int ll_obd_statfs(struct inode *inode, void *arg)
if (rc)
goto out_statfs;
- data = (void*)buf;
+ data = (void *)buf;
if (!data->ioc_inlbuf1 || !data->ioc_inlbuf2 ||
!data->ioc_pbuf1 || !data->ioc_pbuf2) {
rc = -EINVAL;
diff --git a/drivers/staging/lustre/lustre/llite/lloop.c b/drivers/staging/lustre/lustre/llite/lloop.c
index 177137a..a5a4115 100644
--- a/drivers/staging/lustre/lustre/llite/lloop.c
+++ b/drivers/staging/lustre/lustre/llite/lloop.c
@@ -705,7 +705,7 @@ static enum llioc_iter lloop_ioctl(struct inode *unused, struct file *file,
dev = MKDEV(lloop_major, lo->lo_number);
/* quit if the used pointer is writable */
- if (put_user((long)old_encode_dev(dev), (long*)arg)) {
+ if (put_user((long)old_encode_dev(dev), (long *)arg)) {
err = -EFAULT;
goto out;
diff --git a/drivers/staging/lustre/lustre/obdclass/class_obd.c b/drivers/staging/lustre/lustre/obdclass/class_obd.c
index 0b9fac2..377c713 100644
--- a/drivers/staging/lustre/lustre/obdclass/class_obd.c
+++ b/drivers/staging/lustre/lustre/obdclass/class_obd.c
@@ -208,7 +208,7 @@ int class_handle_ioctl(unsigned int cmd, unsigned long arg)
/* only for debugging */
if (cmd == LIBCFS_IOC_DEBUG_MASK) {
- debug_data = (struct libcfs_debug_ioctl_data*)arg;
+ debug_data = (struct libcfs_debug_ioctl_data *)arg;
libcfs_subsystem_debug = debug_data->subs;
libcfs_debug = debug_data->debug;
return 0;
diff --git a/drivers/staging/lustre/lustre/obdclass/lprocfs_status.c b/drivers/staging/lustre/lustre/obdclass/lprocfs_status.c
index 36ab97c..7893c2d 100644
--- a/drivers/staging/lustre/lustre/obdclass/lprocfs_status.c
+++ b/drivers/staging/lustre/lustre/obdclass/lprocfs_status.c
@@ -927,7 +927,7 @@ EXPORT_SYMBOL(lprocfs_rd_num_exports);
int lprocfs_rd_numrefs(struct seq_file *m, void *data)
- struct obd_type *class = (struct obd_type*) data;
+ struct obd_type *class = (struct obd_type *) data;
LASSERT(class != NULL);
return seq_printf(m, "%d\n", class->typ_refcnt);
diff --git a/drivers/staging/lustre/lustre/obdclass/obd_config.c b/drivers/staging/lustre/lustre/obdclass/obd_config.c
index 3359d33..f41695d 100644
--- a/drivers/staging/lustre/lustre/obdclass/obd_config.c
+++ b/drivers/staging/lustre/lustre/obdclass/obd_config.c
@@ -1361,7 +1361,7 @@ int class_config_llog_handler(const struct lu_env *env,
struct config_llog_instance *clli = data;
int cfg_len = rec->lrh_len;
- char *cfg_buf = (char*) (rec + 1);
+ char *cfg_buf = (char *) (rec + 1);
int rc = 0;
//class_config_dump_handler(handle, rec, data);
diff --git a/drivers/staging/lustre/lustre/osc/osc_quota.c b/drivers/staging/lustre/lustre/osc/osc_quota.c
index db4540a..6987261 100644
--- a/drivers/staging/lustre/lustre/osc/osc_quota.c
+++ b/drivers/staging/lustre/lustre/osc/osc_quota.c
@@ -138,7 +138,7 @@ int osc_quota_setdq(struct client_obd *cli, const unsigned int qid[],
static unsigned
oqi_hashfn(struct cfs_hash *hs, const void *key, unsigned mask)
- return cfs_hash_u32_hash(*((__u32*)key), mask);
+ return cfs_hash_u32_hash(*((__u32 *)key), mask);
static int
diff --git a/drivers/staging/lustre/lustre/ptlrpc/connection.c b/drivers/staging/lustre/lustre/ptlrpc/connection.c
index 62154c4..6f63333 100644
--- a/drivers/staging/lustre/lustre/ptlrpc/connection.c
+++ b/drivers/staging/lustre/lustre/ptlrpc/connection.c
@@ -173,7 +173,7 @@ conn_keycmp(const void *key, struct hlist_node *hnode)
const lnet_process_id_t *conn_key;
LASSERT(key != NULL);
- conn_key = (lnet_process_id_t*)key;
+ conn_key = (lnet_process_id_t *)key;
conn = hlist_entry(hnode, struct ptlrpc_connection, c_hash);
return conn_key->nid == conn->c_peer.nid && |
