Staging: iio: Simplify return logic
Author: Cristina Opriceana <cristina.opriceana@gmail.com>
This patch removes the conditional return of the ade77*_probe functions
based on the return values of iio_device_register as the latter
returns 0 or ret, the same as the checked values.
Warning found by coccinelle.
Signed-off-by: Cristina Opriceana
Reviewed-by: Daniel Baluta
 drivers/staging/iio/meter/ade7753.c | 6 +-----
 drivers/staging/iio/meter/ade7754.c | 6 +-----
 drivers/staging/iio/meter/ade7759.c | 6 +-----
 3 files changed, 3 insertions(+), 15 deletions(-)
diff --git a/drivers/staging/iio/meter/ade7753.c b/drivers/staging/iio/meter/ade7753.c
index f828f5f..ffc7f0d 100644
--- a/drivers/staging/iio/meter/ade7753.c
+++ b/drivers/staging/iio/meter/ade7753.c
@@ -517,11 +517,7 @@ static int ade7753_probe(struct spi_device *spi)
 	if (ret)
 		return ret;
-	ret = iio_device_register(indio_dev);
-	if (ret)
-		return ret;
-	return 0;
+	return iio_device_register(indio_dev);
 /* fixme, confirm ordering in this function */
diff --git a/drivers/staging/iio/meter/ade7754.c b/drivers/staging/iio/meter/ade7754.c
index e7171b5..8dc5089 100644
--- a/drivers/staging/iio/meter/ade7754.c
+++ b/drivers/staging/iio/meter/ade7754.c
@@ -540,11 +540,7 @@ static int ade7754_probe(struct spi_device *spi)
 	ret = ade7754_initial_setup(indio_dev);
 	if (ret)
 		return ret;
-	if (ret)
-		return ret;
-	return 0;
diff --git a/drivers/staging/iio/meter/ade7759.c b/drivers/staging/iio/meter/ade7759.c
index 2d5f038..7eef8b9 100644
--- a/drivers/staging/iio/meter/ade7759.c
+++ b/drivers/staging/iio/meter/ade7759.c
@@ -462,11 +462,7 @@ static int ade7759_probe(struct spi_device *spi)
 	if (ret)
 		return ret;
-	if (ret)
-		return ret;
-	return 0;
BtrLinux
Privacy Overview
