staging: sm750fb: remove intialization of static ints
Author: Supriya Karanth <iskaranth@gmail.com>
static ints are initialized to 0 by the compiler.
Explicit initialization is not necessary.
Found by checkpatch.pl - ERROR: do not initialise statics to 0 or NULL
changes made using coccinelle script:
type T;
identifier var;
static T var
- =0
Signed-off-by: Supriya Karanth
drivers/staging/sm750fb/sm750.c | 6 +++---
1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/drivers/staging/sm750fb/sm750.c b/drivers/staging/sm750fb/sm750.c
index 23d67b3..a7b1b9c 100644
--- a/drivers/staging/sm750fb/sm750.c
+++ b/drivers/staging/sm750fb/sm750.c
@@ -46,14 +46,14 @@ typedef int (*PROC_SPEC_INITHW)(struct lynx_share*,struct pci_dev*);
/* common var for all device */
static int g_hwcursor = 1;
-static int g_noaccel = 0;
+static int g_noaccel;
#ifdef CONFIG_MTRR
-static int g_nomtrr = 0;
+static int g_nomtrr;
#endif
static const char * g_fbmode[] = {NULL,NULL};
static const char * g_def_fbmode = "800x600-16@60";
static char * g_settings = NULL;
-static int g_dualview = 0;
+static int g_dualview;
static char * g_option = NULL;
/* if not use spin_lock,system will die if user load driver |
#ifdef CONFIG_MTRR
#endif
