Staging: hv: Transform some kzalloc calls to kcalloc
Author: Nicolas Palix <npalix@diku.dk>
Here is a short excerpt of the semantic patch performing
this transformation:
(http://www.emn.fr/x-info/coccinelle/)
expression E1,E2,E3;
- kzalloc(E1*sizeof(E2),E3)
+ kcalloc(E1,sizeof(E2),E3)
expression E1,E3;
type T;
- kzalloc(E1*sizeof(T),E3)
+ kcalloc(E1,sizeof(T),E3)
Signed-off-by: Nicolas Palix
Cc: Hank Janssen
Cc: Haiyang Zhang
 drivers/staging/hv/storvsc_drv.c | 6 +++---
 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/drivers/staging/hv/storvsc_drv.c b/drivers/staging/hv/storvsc_drv.c
index 62aeb27..b4a82eb 100644
--- a/drivers/staging/hv/storvsc_drv.c
+++ b/drivers/staging/hv/storvsc_drv.c
@@ -473,7 +473,7 @@ static struct scatterlist *create_bounce_buffer(struct scatterlist *sgl, unsigne
 	num_pages = ALIGN_UP(len, PAGE_SIZE) >> PAGE_SHIFT;
-	bounce_sgl = kzalloc(num_pages * sizeof(struct scatterlist), GFP_ATOMIC);
+	bounce_sgl = kcalloc(num_pages, sizeof(struct scatterlist), GFP_ATOMIC);
 	if (!bounce_sgl)
 		return NULL;
@@ -928,14 +928,14 @@ static void storvsc_host_rescan_callback(struct work_struct *work)
 	DPRINT_ENTER(STORVSC_DRV);
 	host_device_ctx = (struct host_device_context*)host->hostdata;
-	lun_list = kzalloc(sizeof(unsigned int)*STORVSC_MAX_LUNS_PER_TARGET, GFP_ATOMIC);
+	lun_list = kcalloc(STORVSC_MAX_LUNS_PER_TARGET, sizeof(unsigned int), GFP_ATOMIC);
 	if (!lun_list)
 		DPRINT_ERR(STORVSC_DRV, "unable to allocate lun list");
 		return;
-	sdevs_remove_list = kzalloc(sizeof(void*)*STORVSC_MAX_LUNS_PER_TARGET, GFP_ATOMIC);
+	sdevs_remove_list = kcalloc(STORVSC_MAX_LUNS_PER_TARGET, sizeof(void *), GFP_ATOMIC);
 	if (!sdevs_remove_list)
 		kfree(lun_list);
BtrLinux
Privacy Overview
