Staging: gdm72xx: clean dev_err logging
Author: Haneen Mohammed <hamohammed.sa@gmail.com>
This patch removes  __func__ from dev_err. dev_err includes information about:
(devcice, driver, specific instance of device, etc) in the log printout.
This was done using Coccinelle, with the following semantic patch:
@a@
expression E, R;
expression  msg;
dev_err(E, msg, __func__, R);
@script:python b@
e << a.msg;
y;
if(e.find("%s: ") == True):
	m = e.replace("%s: ", "", 1);
	coccinelle.y = m;
elif(e.find("%s ") == True):
	m = e.replace("%s ", "", 1);
	coccinelle.y = m;
elif(e.find("%s:") == True):
	m = e.replace("%s:", "", 1);
	coccinelle.y = m;
else:
	m = e.replace("%s", "",1);
	coccinelle.y = m;
@c@
expression a.E, a.msg, a.R;
identifier  b.y;
- dev_err(E, msg, __func__, R);
+ dev_err(E, y, R);
Signed-off-by: Haneen Mohammed
 drivers/staging/gdm72xx/gdm_sdio.c | 6 ++----
 1 file changed, 2 insertions(+), 4 deletions(-)
diff --git a/drivers/staging/gdm72xx/gdm_sdio.c b/drivers/staging/gdm72xx/gdm_sdio.c
index 7a0a0f2..a5fd079 100644
--- a/drivers/staging/gdm72xx/gdm_sdio.c
+++ b/drivers/staging/gdm72xx/gdm_sdio.c
@@ -223,8 +223,7 @@ static void send_sdio_pkt(struct sdio_func *func, u8 *data, int len)
 		if (ret < 0) {
 			if (ret != -ENOMEDIUM)
 				dev_err(&func->dev,
-					"gdmwms: %s error: ret = %d\n",
-					__func__, ret);
+					"gdmwms:  error: ret = %d\n", ret);
 			goto end_io;
@@ -237,8 +236,7 @@ static void send_sdio_pkt(struct sdio_func *func, u8 *data, int len)
 		if (ret < 0) {
 				dev_err(&func->dev,
-					__func__, ret);
 			goto end_io;
BtrLinux
Privacy Overview
