staging: fbtft: Use kmalloc_array
Author: Bhaktipriya Shridhar <bhaktipriya96@gmail.com>
Use kmalloc_array instead of kmalloc for arrays to prevent integer
overflows.
This was done using Coccinelle:
expression e1, e2;
constant C;
type t;
- kmalloc(
+ kmalloc_array(
e2
sizeof(e1), C)
- kmalloc(
+ kmalloc_array(
e1
sizeof(t), C)
- kmalloc(
+ kmalloc_array(
- sizeof(e1)
e2
+ sizeof(e1)
, C)
- kmalloc(
+ kmalloc_array(
- sizeof(t)
e1
+ sizeof(t)
, C)
Signed-off-by: Bhaktipriya Shridhar
 drivers/staging/fbtft/fb_agm1264k-fl.c | 4 ++--
 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/staging/fbtft/fb_agm1264k-fl.c b/drivers/staging/fbtft/fb_agm1264k-fl.c
index 2a50cf9..ba9fc44 100644
--- a/drivers/staging/fbtft/fb_agm1264k-fl.c
+++ b/drivers/staging/fbtft/fb_agm1264k-fl.c
@@ -272,8 +272,8 @@ static int write_vmem(struct fbtft_par *par, size_t offset, size_t len)
 	int ret = 0;
 	/* buffer to convert RGB565 -> grayscale16 -> Dithered image 1bpp */
-	signed short *convert_buf = kmalloc(par->info->var.xres *
-		par->info->var.yres * sizeof(signed short), GFP_NOIO);
+	signed short *convert_buf = kmalloc_array(par->info->var.xres *
+		par->info->var.yres, sizeof(signed short), GFP_NOIO);
 	if (!convert_buf)
 		return -ENOMEM;
BtrLinux
Privacy Overview
