staging: rtl8712: Remove unnecessary parantheses
Author: Bhaktipriya Shridhar <bhaktipriya96@gmail.com>
Removed parantheses on the right hand side of assignments as they are
not needed.
This was done with Coccinelle:
@@ expression a, b; @@
a =
b
Signed-off-by: Bhaktipriya Shridhar
drivers/staging/rtl8712/ieee80211.c | 2 +-
1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/staging/rtl8712/ieee80211.c b/drivers/staging/rtl8712/ieee80211.c
index 974ca02..d13b4d5 100644
--- a/drivers/staging/rtl8712/ieee80211.c
+++ b/drivers/staging/rtl8712/ieee80211.c
@@ -376,7 +376,7 @@ int r8712_get_sec_ie(u8 *in_ie, uint in_len, u8 *rsn_ie, u16 *rsn_len,
uint cnt;
/*Search required WPA or WPA2 IE and copy to sec_ie[ ]*/
- cnt = (_TIMESTAMP_ + _BEACON_ITERVAL_ + _CAPABILITY_);
+ cnt = _TIMESTAMP_ + _BEACON_ITERVAL_ + _CAPABILITY_;
while (cnt < in_len) {
authmode = in_ie[cnt];
if ((authmode == _WPA_IE_ID_) && |
uint cnt;
