Staging: dgnc: Use goto for error handling
Author: Quentin Lambert <lambert.quentin@gmail.com>
This patch introduces goto statments for error handling
and in cases where a lock needs to be released.
A simplified version of the semantic patch that finds this problem is as
follows: (http://coccinelle.lip6.fr)
@candidates exists@
identifier f, label;
statement s;
position p1, p2, p3;
  f@p1(...) {
  ...when any
    if@p2(...) {
    ...when any
      s
      return@p3 ...;
  ...when any
@good1 exists@
identifier candidates.f, candidates.label;
statement candidates.s;
position candidates.p1, candidates.p2;
  f@p1(...) {
  ...when any
    if(...) {
    ...when any
      s
      return ...;
    ...when any
    if@p2(...) {...}
  ...when any
@depends on good1@
position candidates.p1, candidates.p3;
   f@p1(...) {
   ...when any
*  return@p3 ...;
Signed-off-by: Quentin Lambert
 drivers/staging/dgnc/dgnc_cls.c    | 19 +++++++------------
 drivers/staging/dgnc/dgnc_driver.c | 14 +++-----------
 drivers/staging/dgnc/dgnc_neo.c    | 30 ++++++++++++------------------
 3 files changed, 22 insertions(+), 41 deletions(-)
diff --git a/drivers/staging/dgnc/dgnc_cls.c b/drivers/staging/dgnc/dgnc_cls.c
index 634d3ea..66397d6 100644
--- a/drivers/staging/dgnc/dgnc_cls.c
+++ b/drivers/staging/dgnc/dgnc_cls.c
@@ -988,22 +988,16 @@ static void cls_copy_data_from_queue_to_uart(struct channel_t *ch)
 	spin_lock_irqsave(&ch->ch_lock, flags);
 	/* No data to write to the UART */
-	if (ch->ch_w_tail == ch->ch_w_head) {
-		spin_unlock_irqrestore(&ch->ch_lock, flags);
-		return;
+	if (ch->ch_w_tail == ch->ch_w_head)
+		goto exit_unlock;
 	/* If port is "stopped", don't send any data to the UART */
 	if ((ch->ch_flags & CH_FORCED_STOP) ||
-				 (ch->ch_flags & CH_BREAK_SENDING)) {
-		return;
+				 (ch->ch_flags & CH_BREAK_SENDING))
+		goto exit_unlock;
-	if (!(ch->ch_flags & (CH_TX_FIFO_EMPTY | CH_TX_FIFO_LWM))) {
-		return;
+	if (!(ch->ch_flags & (CH_TX_FIFO_EMPTY | CH_TX_FIFO_LWM)))
+		goto exit_unlock;
 	n = 32;
@@ -1053,6 +1047,7 @@ static void cls_copy_data_from_queue_to_uart(struct channel_t *ch)
 	if (len_written > 0)
 		ch->ch_flags &= ~(CH_TX_FIFO_EMPTY | CH_TX_FIFO_LWM);
+exit_unlock:
diff --git a/drivers/staging/dgnc/dgnc_driver.c b/drivers/staging/dgnc/dgnc_driver.c
index ec7c155..9ae9014 100644
--- a/drivers/staging/dgnc/dgnc_driver.c
+++ b/drivers/staging/dgnc/dgnc_driver.c
@@ -549,30 +549,19 @@ static int dgnc_found_board(struct pci_dev *pdev, int id)
 	rc = dgnc_tty_register(brd);
 	if (rc < 0) {
-		dgnc_tty_uninit(brd);
 		pr_err(DRVSTR ": Can't register tty devices (%d)\n", rc);
-		brd->state = BOARD_FAILED;
-		brd->dpastatus = BD_NOFEP;
 		goto failed;
 	rc = dgnc_finalize_board_init(brd);
 	if (rc < 0) {
 		pr_err(DRVSTR ": Can't finalize board init (%d)\n", rc);
 		goto failed;
 	rc = dgnc_tty_init(brd);
 	if (rc < 0) {
 		pr_err(DRVSTR ": Can't init tty devices (%d)\n", rc);
 		goto failed;
@@ -606,6 +595,9 @@ static int dgnc_found_board(struct pci_dev *pdev, int id)
 	return 0;
 failed:
+	dgnc_tty_uninit(brd);
+	brd->state = BOARD_FAILED;
+	brd->dpastatus = BD_NOFEP;
 	return -ENXIO;
diff --git a/drivers/staging/dgnc/dgnc_neo.c b/drivers/staging/dgnc/dgnc_neo.c
index 12e61ca..41105be 100644
--- a/drivers/staging/dgnc/dgnc_neo.c
+++ b/drivers/staging/dgnc/dgnc_neo.c
@@ -1420,16 +1420,13 @@ static void neo_copy_data_from_queue_to_uart(struct channel_t *ch)
-		return;
+		goto exit_unlock;
-	if ((ch->ch_flags & CH_FORCED_STOP) || (ch->ch_flags & CH_BREAK_SENDING)) {
-		return;
+	if ((ch->ch_flags & CH_FORCED_STOP) ||
+		goto exit_unlock;
 	 * If FIFOs are disabled. Send data directly to txrx register
@@ -1470,27 +1467,23 @@ static void neo_copy_data_from_queue_to_uart(struct channel_t *ch)
 			ch->ch_w_tail &= WQUEUEMASK;
 			ch->ch_txcount++;
-		return;
+		goto exit_unlock;
 	 * We have to do it this way, because of the EXAR TXFIFO count bug.
 	if ((ch->ch_bd->dvid & 0xf0) < UART_XR17E158_DVID) {
-			return;
+			goto exit_unlock;
 		len_written = 0;
 		n = readb(&ch->ch_neo_uart->tfifo);
-		if ((unsigned int) n > ch->ch_t_tlevel) {
-			return;
+		if ((unsigned int) n > ch->ch_t_tlevel)
+			goto exit_unlock;
 		n = UART_17158_TX_FIFOSIZE - ch->ch_t_tlevel;
 	} else {
@@ -1554,6 +1547,7 @@ static void neo_copy_data_from_queue_to_uart(struct channel_t *ch)
+exit_unlock:
BtrLinux
Privacy Overview
