Author: Somya Anand <somyaanand214@gmail.com>
The function setup_timer combines the initialization of a timer with the
initialization of the timer's function and data fields.
So, this patch combines the multiline code for timer initialization using the function
setup_timer. This issue is identified via coccinelle script.
expression E1, E2, E3;
type T;
- init_timer(&E1);
- E1.function = E2;
- E1.data = (T)E3;
+ setup_timer(&E1, E2, (T)E3);
- E1.data = (T)E3;
- E1.function = E2;
- E1.function = E2;
+ setup_timer(&E1, E2, 0);
Signed-off-by: Somya Anand
.../staging/rtl8192u/ieee80211/ieee80211_module.c | 5 +-
.../staging/rtl8192u/ieee80211/rtl819x_TSProc.c | 55 +++++++---------------
drivers/staging/rtl8192u/r8192U_core.c | 5 +-
drivers/staging/rtl8192u/r8192U_dm.c | 6 +--
4 files changed, 24 insertions(+), 47 deletions(-)
diff --git a/drivers/staging/rtl8192u/ieee80211/ieee80211_module.c b/drivers/staging/rtl8192u/ieee80211/ieee80211_module.c
index 9a60725..31233d8 100644
--- a/drivers/staging/rtl8192u/ieee80211/ieee80211_module.c
+++ b/drivers/staging/rtl8192u/ieee80211/ieee80211_module.c
@@ -133,9 +133,8 @@ struct net_device *alloc_ieee80211(int sizeof_priv)
ieee->ieee802_1x = 1; /* Default to supporting 802.1x */
INIT_LIST_HEAD(&ieee->crypt_deinit_list);
- init_timer(&ieee->crypt_deinit_timer);
- ieee->crypt_deinit_timer.data = (unsigned long)ieee;
- ieee->crypt_deinit_timer.function = ieee80211_crypt_deinit_handler;
+ setup_timer(&ieee->crypt_deinit_timer,
+ ieee80211_crypt_deinit_handler, (unsigned long)ieee);
spin_lock_init(&ieee->lock);
spin_lock_init(&ieee->wpax_suitlist_lock);
diff --git a/drivers/staging/rtl8192u/ieee80211/rtl819x_TSProc.c b/drivers/staging/rtl8192u/ieee80211/rtl819x_TSProc.c
index acaa723..0345f1c 100644
--- a/drivers/staging/rtl8192u/ieee80211/rtl819x_TSProc.c
+++ b/drivers/staging/rtl8192u/ieee80211/rtl819x_TSProc.c
@@ -156,26 +156,16 @@ void TSInitialize(struct ieee80211_device *ieee)
pTxTS->num = count;
// The timers for the operation of Traffic Stream and Block Ack.
// DLS related timer will be add here in the future!!
- init_timer(&pTxTS->TsCommonInfo.SetupTimer);
- pTxTS->TsCommonInfo.SetupTimer.data = (unsigned long)pTxTS;
- pTxTS->TsCommonInfo.SetupTimer.function = TsSetupTimeOut;
- init_timer(&pTxTS->TsCommonInfo.InactTimer);
- pTxTS->TsCommonInfo.InactTimer.data = (unsigned long)pTxTS;
- pTxTS->TsCommonInfo.InactTimer.function = TsInactTimeout;
- init_timer(&pTxTS->TsAddBaTimer);
- pTxTS->TsAddBaTimer.data = (unsigned long)pTxTS;
- pTxTS->TsAddBaTimer.function = TsAddBaProcess;
- init_timer(&pTxTS->TxPendingBARecord.Timer);
- pTxTS->TxPendingBARecord.Timer.data = (unsigned long)pTxTS;
- pTxTS->TxPendingBARecord.Timer.function = BaSetupTimeOut;
- init_timer(&pTxTS->TxAdmittedBARecord.Timer);
- pTxTS->TxAdmittedBARecord.Timer.data = (unsigned long)pTxTS;
- pTxTS->TxAdmittedBARecord.Timer.function = TxBaInactTimeout;
+ setup_timer(&pTxTS->TsCommonInfo.SetupTimer, TsSetupTimeOut,
+ (unsigned long)pTxTS);
+ setup_timer(&pTxTS->TsCommonInfo.InactTimer, TsInactTimeout,
+ setup_timer(&pTxTS->TsAddBaTimer, TsAddBaProcess,
+ setup_timer(&pTxTS->TxPendingBARecord.Timer, BaSetupTimeOut,
+ setup_timer(&pTxTS->TxAdmittedBARecord.Timer,
+ TxBaInactTimeout, (unsigned long)pTxTS);
ResetTxTsEntry(pTxTS);
list_add_tail(&pTxTS->TsCommonInfo.List, &ieee->Tx_TS_Unused_List);
pTxTS++;
@@ -189,23 +179,14 @@ void TSInitialize(struct ieee80211_device *ieee)
pRxTS->num = count;
INIT_LIST_HEAD(&pRxTS->RxPendingPktList);
- init_timer(&pRxTS->TsCommonInfo.SetupTimer);
- pRxTS->TsCommonInfo.SetupTimer.data = (unsigned long)pRxTS;
- pRxTS->TsCommonInfo.SetupTimer.function = TsSetupTimeOut;
- init_timer(&pRxTS->TsCommonInfo.InactTimer);
- pRxTS->TsCommonInfo.InactTimer.data = (unsigned long)pRxTS;
- pRxTS->TsCommonInfo.InactTimer.function = TsInactTimeout;
- init_timer(&pRxTS->RxAdmittedBARecord.Timer);
- pRxTS->RxAdmittedBARecord.Timer.data = (unsigned long)pRxTS;
- pRxTS->RxAdmittedBARecord.Timer.function = RxBaInactTimeout;
- init_timer(&pRxTS->RxPktPendingTimer);
- pRxTS->RxPktPendingTimer.data = (unsigned long)pRxTS;
- pRxTS->RxPktPendingTimer.function = RxPktPendingTimeout;
+ setup_timer(&pRxTS->TsCommonInfo.SetupTimer, TsSetupTimeOut,
+ (unsigned long)pRxTS);
+ setup_timer(&pRxTS->TsCommonInfo.InactTimer, TsInactTimeout,
+ setup_timer(&pRxTS->RxAdmittedBARecord.Timer,
+ RxBaInactTimeout, (unsigned long)pRxTS);
+ setup_timer(&pRxTS->RxPktPendingTimer, RxPktPendingTimeout,
ResetRxTsEntry(pRxTS);
list_add_tail(&pRxTS->TsCommonInfo.List, &ieee->Rx_TS_Unused_List);
pRxTS++;
diff --git a/drivers/staging/rtl8192u/r8192U_core.c b/drivers/staging/rtl8192u/r8192U_core.c
index 8f7a321..b6cd7ea 100644
--- a/drivers/staging/rtl8192u/r8192U_core.c
+++ b/drivers/staging/rtl8192u/r8192U_core.c
@@ -2549,9 +2549,8 @@ static short rtl8192_init(struct net_device *dev)
rtl8192_read_eeprom_info(dev);
rtl8192_get_channel_map(dev);
init_hal_dm(dev);
- init_timer(&priv->watch_dog_timer);
- priv->watch_dog_timer.data = (unsigned long)dev;
- priv->watch_dog_timer.function = watch_dog_timer_callback;
+ setup_timer(&priv->watch_dog_timer, watch_dog_timer_callback,
+ (unsigned long)dev);
if (rtl8192_usb_initendpoints(dev) != 0) {
DMESG("Endopoints initialization failed");
return -ENOMEM;
diff --git a/drivers/staging/rtl8192u/r8192U_dm.c b/drivers/staging/rtl8192u/r8192U_dm.c
index 16cafcd..4c62cb8 100644
--- a/drivers/staging/rtl8192u/r8192U_dm.c
+++ b/drivers/staging/rtl8192u/r8192U_dm.c
@@ -2681,10 +2681,8 @@ static void dm_init_fsync(struct net_device *dev)
priv->ieee80211->fsync_seconddiff_ratethreshold = 200;
priv->ieee80211->fsync_state = Default_Fsync;
priv->framesyncMonitor = 1; /* current default 0xc38 monitor on */
- init_timer(&priv->fsync_timer);
- priv->fsync_timer.data = (unsigned long)dev;
- priv->fsync_timer.function = dm_fsync_timer_callback;
+ setup_timer(&priv->fsync_timer, dm_fsync_timer_callback,
static void dm_deInit_fsync(struct net_device *dev) |
pTxTS->num = count;
pTxTS++;
pRxTS->num = count;
pRxTS++;
init_hal_dm(dev);
return -ENOMEM;
