Staging: dgnc: Compress two lines of code into one.
Author: Heena Sirwani <heenasirwani@gmail.com>
The following patch merges two lines of code into one using coccinelle
and removes unused variables. The semantic patch used is as follows:
expression ret;
identifier f;
-ret =
+return
     f(...);
-return ret;
Signed-off-by: Heena Sirwani
 drivers/staging/dgnc/dgnc_cls.c | 6 ++----
 1 file changed, 2 insertions(+), 4 deletions(-)
diff --git a/drivers/staging/dgnc/dgnc_cls.c b/drivers/staging/dgnc/dgnc_cls.c
index a17f4f6..f0b1ec7 100644
--- a/drivers/staging/dgnc/dgnc_cls.c
+++ b/drivers/staging/dgnc/dgnc_cls.c
@@ -964,7 +964,6 @@ static int cls_drain(struct tty_struct *tty, uint seconds)
 	unsigned long flags;
 	struct channel_t *ch;
 	struct un_t *un;
-	int rc = 0;
 	if (!tty || tty->magic != TTY_MAGIC)
 		return -ENXIO;
@@ -984,12 +983,11 @@ static int cls_drain(struct tty_struct *tty, uint seconds)
 	 * NOTE: Do something with time passed in.
-	rc = wait_event_interruptible(un->un_flags_wait,
-					 ((un->un_flags & UN_EMPTY) == 0));
 	/* If ret is non-zero, user ctrl-c'ed us */
-	return rc;
+	return wait_event_interruptible(un->un_flags_wait,
+					 ((un->un_flags & UN_EMPTY) == 0));
BtrLinux
Privacy Overview
