Staging: lustre: Replace non-standard spinlock macro definations
Author: Vaishali Thakkar <vthakkar1994@gmail.com>
This patch replaces non-standard spin lock macro with standard linux function.
This is done using Coccinelle and semantic patch used is as follows:
expression x;
- TREE_READ_LOCK_IRQ(x)
+ spin_lock_irq(&(x)->tree_lock)
expression x;
- TREE_READ_UNLOCK_IRQ(x)
+ spin_unlock_irq(&(x)->tree_lock)
Also semantic patch result is modified by droping ->,
inner & and adding . for simplification of code.
Signed-off-by: Vaishali Thakkar
Acked-by: Julia Lawall
drivers/staging/lustre/lustre/llite/llite_lib.c | 4 ++--
1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/staging/lustre/lustre/llite/llite_lib.c b/drivers/staging/lustre/lustre/llite/llite_lib.c
index a8bcc51..d614752 100644
--- a/drivers/staging/lustre/lustre/llite/llite_lib.c
+++ b/drivers/staging/lustre/lustre/llite/llite_lib.c
@@ -1880,8 +1880,8 @@ void ll_delete_inode(struct inode *inode)
/* Workaround for LU-118 */
if (inode->i_data.nrpages) {
- TREE_READ_LOCK_IRQ(&inode->i_data);
- TREE_READ_UNLOCK_IRQ(&inode->i_data);
+ spin_lock_irq(&inode->i_data.tree_lock);
+ spin_unlock_irq(&inode->i_data.tree_lock);
LASSERTF(inode->i_data.nrpages == 0,
"inode=%lu/%u(%p) nrpages=%lu, see "
"http://jira.whamcloud.com/browse/LU-118\n", |
